Finding currents I1, I2, I3 in a multi-loop circuit
  • Topic: Engineering
  • Thread starter TheTopGun
    Circuits
TheTopGun
Hello! I'm having difficulty analyzing https://dl.dropboxusercontent.com/u/53341615/Circuit%20Diagram.png circuit and determining the currents I1,I2,I3.
Ohm's Law
Kirchoffs Laws
Current and Volatage divider
So far all I can manage is https://dl.dropboxusercontent.com/u/53341615/IMG_20130827_211859.jpg the circuit, I am sure I am suppose to use current or voltage divider I just can't work out where.
Using software simulation the values should be around ...I1=0.5404, I2=0.8109, I3= -0.2702mA
Any help on which rules and where to apply them would be much appreciated!
~thanks
Ohm's Law
Kirchoffs Laws
~thanks
Your simplified circuit is correct except you have a typo for the left resistor. Should be kOhms, not Ohms.
In problems like this, I prefer to write the KCL equations, and just solve them simultaneously. That's the most intuitive technique for me, and almost always works without modification.
So this is a pretty simple circuit -- call the voltage at the top node V1, and write the one KCL equation for that node. You can then solve for that voltage, which let's you solve for the 3 currents that the problem is asking for. In problems with multiple nodes, just write the KCL equations for each node and solve the equations simultaneously.
I prefer to write the KCL equation(s) as the sum of all the currents out of each node equal zero.
Can you show us your work given those hints?
Ahh thankyou very much. I was messing around with equations I didn't need. I just wrote out the Ohms, KCL & KVL equations then solved simultaneously, came out perfect.
Once again, thanks :)
