Finding discontinuities in functions
The discussion focuses on identifying discontinuities in the function f(x) = (x+2)/√((x+2)x). Participants emphasize the importance of recognizing values that lead to division by zero or undefined expressions, specifically at x = 0 and x = -2. The conversation also highlights the distinction between removable and non-removable discontinuities, urging users to clarify definitions from their course materials. Additionally, the use of LaTeX for clearer mathematical expression is recommended for better communication.
  • Understanding of algebraic functions and their properties
  • Knowledge of limits and continuity in calculus
  • Familiarity with removable and non-removable discontinuities
  • Basic skills in LaTeX for mathematical notation
  • Study the concept of limits, particularly one-sided limits
  • Learn about removable and non-removable discontinuities in depth
  • Practice identifying discontinuities in various algebraic functions
  • Explore LaTeX formatting for mathematical expressions
Students studying calculus, particularly those learning about function discontinuities, as well as educators seeking to clarify mathematical notation and concepts in their teaching materials.
Schaus
Where are the following functions discontinuous?
= (x+2)/x√(2x) multiply both denominator and numerator by √(2x)
= (x√2+2√x)/(x(2x))
Can I leave it like this and state that x ≠ 0, or have I gone horribly wrong? Otherwise, I'm a little lost. The other questions similar to this that I have done usually consist of factoring out and cancelling a binomial in the numerator with a binomial in the denominator.
f(x) = x+2/√((x+2)x)
= x+2/x√(2x) multiply both denominator and numerator by √(2x)
= (x√2+2√x)/(x(2x))
Do you mean
$$f(x) = x + \frac{2}{\sqrt{x(x+2)}},$$
or do you mean
$$f(x) = \frac{ x+2}{\sqrt{x(x+2)}}?$$
Interpreted literally, what you wrote means the first one.
Sorry was meant to be the second one. By the way how do you write questions in that form? Would be much simpler for people to understand what I'm trying to ask if I could display them properly.
You should begin the search for discontinuities in a function that is defined by an algebraic expression by looking at the expression in its original form. Look for values of ##x## that would cause division by zero. Look for values of ##x## that would cause a function like ##\sqrt{()}## or ##\log()## to be undefined.
Then you have to understand the conventions used by your course material. In particular, is a value of ##x## for which the algebraic expression is not a defined supposed to be considered a "discontinuity" of the function or is it merely to be considered a value that is "not in the domain of the function" ?
Notice that you can't do such a manipulation unless ##\sqrt{2x}## is a number. Assuming you are dealing only with the real number system, you would have to assume ##2x## was not a negative number. When trying to do deductive reasoning with algebraic manipulations, you must keep track of such assumptions as you proceed. You can't just wait until to the very end of the process to deduce what restrictions apply to ##x##.
The type of manipulations you are doing may be relevant to determining whether a discontinuity is a "removable discontinuity". Have you studied removable discontinuities?
So before I do anything I should state the restrictions on the denominator? Which are x ≠ 0 and x ≡ -2, I believe.
Can ## x = -1.3 ##?
No it can not...
Do I simply state that it has a discontinuity at x = -2 but isn't removable then because otherwise I'm at a loss.
The only safe course of action is to look at examples from your course materials and infer what to do. Can you quote a similar example for us? My guess is that the problem wants you to consider ##lim_{x \rightarrow 0} f(x) ## and ##lim_{x \rightarrow -2} f(x) ##, perhaps by looking at the two-sided limits in each case. If that's what is expected, then your course materials are being careless about certain technicalities - which sometimes happens in our education.
As I indicated, you'll have to straighten out the particular terminology used in your course materials. Some people might say the function is discontinuous at x = -1.3 because it is "not continuous at x = a". Other people might say only that "x = -1.3 is not in the domain of the function" because they regard a definition of a function by an algebraic expression as implicitly excluding values that make the algebraic expression undefined. They might not say "x = -1.3 is a discontinuity of f(x) " because their definition of "discontinuity" requires that the discontinuity occur at a value in the domain of the function.
If your dealing with course materials that expect you to classify each discontinuity as one of 3 types, "removable", "jump" or "essential" then (I think) this implies that a value that is a discontinuity must be in the domain of the function. However, course materials can be careless, Perhaps the the problem should have defined the function as:
## f(x) = \frac{(x+2)}{\sqrt{(x)(x+2)}} ## when ##(x)(x+2) > 0##
and ##f(x) = 0## when ##x= -2## or ##x = 0##.
That definition would include ##x = -2## and ##x = 0## as values in the domain of ##f##.
Just use parentheses, like this: f(x) = (x+2)/√(x(x+2)). The point is that a+b/c means ##a + \frac{b}{c}##, so if you want ##\frac{a+b}{c}## you need to put the numerator in brackets: (a+b)/c. Similarly, a/b+c means ##\frac{a}{b}+c##, so if you mean ##\frac{a}{b+c}## you need to put the denominator in brackets: a/(b+c). Better still: take a few minutes to learn the basics of LaTeX. For in-line LaTeX formulas you still need to use parentheses, but the results look a lot better: ##f(x) = (x+2)/\sqrt{x(x+2)}##.
The only other question I have to compare to is f(x) = (x2-x)/(x2-1) which I've factored and eliminated discontinuity. (x(x-1))/(x-1)(x+1). I take out the (x-1) so x ≠ 1 and I am left with x/(x+1). The question above is the first I've encountered with a radical and it has thrown me off, considering I am still trying to grasp this whole limit concept. I will definitely look into in-line LaTeX formulas! Thanks for the info
