Finding displacement from velocity using the net change theorem
14 replies · 4K views
MitsuShai
2. The attempt at a solution
I integrated the velocity equation and got this: s(t)= sin(t) + (1/2)x
1. [sin(pi)+(1/2)(pi)] - [sin(0)+(1/2)(0)]
= pi/2
2. [sin(pi)+(1/2)(pi)] + [sin(0)+(1/2)(0)]
= pi/2
The first answer is right but the second one isn't
Number one is right. The problem with two is that at e.g. v(pi)=(-1/2). So the particle is traveling backwards part of the time.
But even if it's traveling backwards, it does not effect the total distance right? Because that will effect the displacement.
You've got that backwards. Displacement is the total distance between the starting point and the ending point. It doesn't matter how you got from the start to the end. How you did does affect the total distance travelled.
ok then, but I still can't think of a way to solve it.
Find out at what time the particle switches from going forward to backwards by solving v(t)=0. Then add the distance it travels forward to the distance it travels backward.
v(t)=cos(t)+(1/2)=0
cos (t)= -1/2
t=2pi/3
[sin(0)+(1/2)(0)] + [sin(2pi/3)+(1/2)(2pi/3)]
0 + squareroot(3)/2 + pi/6...
MitsuShai said:
v(t)=cos(t)+(1/2)=0
cos (t)= -1/2
t=2pi/3
(1/2)(2pi/3)=pi/3. So if you mean sqrt(3)/2+pi/3, then, yes, that's the distance it travels forward. Now how far does it travel backwards?
that was only the forward one; i thought I was solving for both. ok let's see now:
[sin(2pi/3)+(1/2)(2pi/3)] + [sin(pi)+(1/2)(pi)]
sqrt(3)/2+pi/3 + 0
=sqrt(3)/2+pi/3
forward + backward=
(sqrt(3)/2+pi/3) + (sqrt(3)/2+pi/3)
2(sqrt(3)/2+pi/3)
sqrt(3)/2+pi/3 + 0
=sqrt(3)/2+pi/3
forward + backward=
2(sqrt(3)/2+pi/3)
To get the backwards distance you are integrating v(t) from 2pi/3 to pi and then reversing the sign since you know the result will be negative, and you want the positive distance, right? So shouldn't [sin(2pi/3)+(1/2)(2pi/3)] + [sin(pi)+(1/2)(pi)] be [sin(2pi/3)+(1/2)(2pi/3)] - [sin(pi)+(1/2)(pi)]??
oh yeah that's right, but won't you still end up with the same answer?
sqrt(3)/2+pi/3
then add the forward distance with the backward distance? But then the answer turns out weird...
sqrt(3)/2+pi/3
No, I don't get sqrt(3)/2+pi/3 for the backwards distance. The difference between the forward distance and the backwards distance should be the displacement, right? It's not zero. Try the backwards distance again.
[squareroot(3)/2 + pi/3] - [0+ pi/2] ---sorry about that I assumed it was zero because of the forward direction one, that was a stupid mistake
squareroot(3)/2 + pi/3 - pi/2
squareroot(3)/2 -pi/6
forward + backwards=
sqrt(3)/2+pi/3 + squareroot(3)/2 -pi/6
2(sqrt(3)/2)+ 3pi/18
= sqrt(3) + 3pi/18
= sqrt(3) + 3pi/18
That's better. You can simplify 3pi/18 to pi/6. But now I think it's right.
Thank you so much; it is right :)
