Finding distance and charge ratio from zero potential points
  • Thread starter Thread starter pmd28
    Potential
9 replies · 3K views · last reply
pmd28
A positive charge +q1 is located to the left of a negative charge −q2. On a line passing through the two charges, there are two places where the total potential is zero. The first place is between the charges and is 3.35 cm to the left of the negative charge. The second place is 7.65 cm to the right of the negative charge.
(a) What is the distance between the charges?
(b) Find |q1|/|q2|, the ratio of the magnitudes of the charges
V=kq/r
I don't know where to start. I know that I need to solve for the distance between +q1 and the spot 3.35 cm to the left of the negative charge to be able to solve for the distance between them. I'm just not sure how to use the charge to the right of -q2.
Start by drawing a diagram of the setup. Label the distance between the charges as d.
What equations can you write to describe the given conditions?
See that's the thing, I'm still iffy on the relationshiphs. My best educated guess would be:
Since V @ .0335m is equal to zero. That would mean the net electric field at that point is also 0 because E=-ΔV/Δs.
Or am I going in a completely wrong direction.
You can work with the electric field or the potential. The potential is simpler as it is a scalar value that depends only on the charge and the distance from it. Since the problem statement specifically mentions potential, that would suggest that potential is a likely way to proceed :smile:
What's the expression for the electric potential at a distance r from a charge q?
pmd28 said:
V=kq/r
Yes, that's correct. So write expressions for the potential at the two given locations assuming that the distance between the charges is d.
Ok, sorry I had a spark of genius. And I've been kind of going with it. I just want to know if I'm on the right track. I set the +q1 charges equal to each other and got:
r=.11/(V1-V2)
Then I set the -q2 charges equal to each other and got:
.035V1=.0765V2
Substitute to get
r=.11/(V1-.035V1)
I got stuck again. I need one more equation, but I just can't seem to find it.
r=.11/(V1-V2)
.035V1=.0765V2
Substitute to get
r=.11/(V1-.035V1)
You'll have to explain the above in detail. I don't understand what the equations are meant to represent. In particular, what are the "+q1 charges" and "-q2 charges"? The problem statement mentions only two charges, +q1 and -q2. And the potentials of interest are both zero.
