Finding dy/dx using the chain rule with substituted variables
  • Thread starter Thread starter ar202
13 replies · 3K views · last reply
ar202
for each of the following find dy/dx, expressing the answer as a function of x.
(A) y=z7, z=sin(x)
(B) y=√z , z=x4+1
I'm having some trouble working out what the question is actually asking me to do... If i go at it normally i get for eg 7z6cos(x) ... but this isn't the answer.
Express the answer as a function of x. (Get rid of that z!)
so I'm literally just replacing the z?
sin(x)7sin(x)
becomes
7sin(x)6cos(x)
the 2nd line looks ok, but why do you start with sin(x)7sin(x)?
also to help people help you, try & be clear in what you want to communicate and try and give all the info eg.
so substituting in for z(x) = sin(x) gives
y(x) = sin(x)7
then differentiating w.r.t. x
y'(x) = 7sin(x)6cos(x)
lanedance said:
the 2nd line look ok, but why do you start with sin(x)7sin(x)?
i was replacing the z... prob mixed up the steps
Are these questions based on the chain rule?
Yes. Your answer of 7z6cos(x) becomes 7sin6(x)cos(x).
yes & and that's exactly what you've used
ok cool, because i was doing some work on products and quotients and then got hit with these so was a little thrown.
thanks for your help!
ps Any help with (B) :p
in both cases you are given y(z) and z(x), then substitute to get y(z(x))
the derivative of y w.r.t. the chain rule is
[tex]\frac{dy(z(x))}{dx} = \frac{dy(z)}{dz} \frac{dz(x)}{dx}[/tex]
noting as you did early on you need to substitute in for z = z(x) in the final answer if any remain
ok I am kinda struggling with the latex code... what a ballache! apologies if this is confusing
z=1/2√z & z=x4+1 = 4x3
then i get
4x3/2√x4+1
how does that look...?
It should be y = (1/2)sqrt(z) + 1. You don't want z to be defined as the square root of itself. Then, if z = z=x4+1, dz/dx = 4x3, not z.
ar202 said:
then i get
4x3/2√x4+1
Other than it's incorrect? It should be written as an equation that identifies what you have found.
You might find it easier to work with exponents rather than radicals. y = (1/2)z1/2. dy/dx = dy/dz * dz/dx
ok. thanks for the help dude
