Finding Eigenvectors for Coordinate transformation
The discussion centers around the challenges of transforming operators from an original basis into the eigenbasis of a complex Hermitian matrix (Hamiltonian) in quantum mechanics. The user, Philip, highlights the non-uniqueness of the eigenvector matrix V due to the presence of commuting matrices, which affects the transformation of other operators like matrix X. The conversation reveals that if the eigenvalues of the Hamiltonian are distinct, the eigenvectors are unique up to a phase factor, but if they are not, the eigenbasis can vary, complicating transformations. A solution discussed involves adjusting the phase of the eigenvectors to ensure their diagonal elements are real, which simplifies calculations and enhances numerical stability. The thread concludes with Philip expressing satisfaction with the solution and the hope that it may help others facing similar issues.
pjg
I'm wondering if anyone here might have a solution to a problem I've having. This is a Quantum Mechanics problem I'm doing.
I calculate a 4 by 4 complex Hermitian matrix (H = Hamiltonian) in a basis where it is not diagonal. I diagonalize it numerically (using eispack) and get eigenvalues and eigenvectors, V. With the eigenvector matrix, V, I have verified that the Hamiltonian in the original basis is transformed into a diagonal matrix in the eigenbasis of H. That is,
D = Vadj H V
Now I want to move some other Operators (matrices) from my original basis into the eigenbasis of H. For example, I want to transform matrix X into the eigenbasis of H.
X* = Vadj X V
Here's my problem. There is not a unique V to transform H into D. That is, I could use
Vo = V exp(i B)
where B is a matrix that commutes with D. i.e., BD-DB = 0.
So I still get
Voadj H Vo = exp(-iB) Vadj H V exp(iB) = exp(-iB) D exp(iB) = D
but since XB - BX != 0 (i.e., X and B don't commute), then I get different answers when transforming X into the eigenbasis of H depending on whether my diagonalization routine gives me V or Vo back for the eigenvectors.
Does anyone know what this problem is called? Does anyone know of someplace I can read more, and possibly find a solution?
Thanks,
Philip
In order to preserve the probability space,the theorem of Wigner states that the operators which transform the vectors and observables must be either
* linear and unitary.
* antilinear and antiunitary.
Check your operators obey Wigner's theorem.
Daniel.
If the eigenvalues of H are distinct, then it has a unique (up to an arbitrary phase for each eigenvector) set of orthonormal eigenvectors that form a basis for the 4-d space***. In this case, the only difference between V and Vo is that each column in V generally has a different phase from the corresponding column in Vo. Therefore Voadj X Vo = Vadj X V.
On the other hand, if the eigenvalues E_k of H are not distinct, then the orthonormal eigenbasis is not unique. For example, if the eigenvalue E_j has multiplicity m, then the eigenvectors with eigenvalue E_j form an m-dimensional subspace. If you pick any m linearly independent vectors from this subspace, you can construct from them an orthonormal basis for the subspace using the Gram-Schmidt method. Any vector in this subspace is automatically orthogonal to all eigenvectors corresponding to eigenvalues other than E_j. However, the particular orthonormal basis you construct for the subspace depends on your initial choice of m independent vectors. So in this case of non-distinct eigenvalues, the difference between V and Vo will generally correspond to a different choice in orthonormal bases for each subspace corresponding to a repeated eigenvalue. So some columns of Vo will be linear combinations of columns in V. And that will generally lead to a different transformation of X. So you're right, the result of transforming the matrix of X into an eigenbasis of H will generally depend on which eigenbasis you choose. Even if you decided to stick with one set of basis eigenvectors, the representation of X in that basis would depend on how you numbered them. Of course, the order of the diagonal elements of D would also depend on this numbering, which is a different situation than what we were dealing with above.
***A similar statement is true for any nxn matrix A with n distinct eigenvalues...it has a unique set of normalized eigenvectors (not necessarily orthogonal). For example, let u_1, u_2, ..., u_n be eigenvectors of A corresponding to the eigenvalues E_1, E_2, ..., E_n. Since the E_j's are distinct, the u_j's are linearly independent and form a basis for the n-dimensional space. Now suppose a vector "w" is an eigenvector of A corresponding to eigenvalue E_k. We can write w as a linear combination of the basis vectors:
w = c_1 u_1 + c_2 u_2 + ... + c_n u_n
Applying A to both sides of this equation, we get
E_k w = c_1 E_1 u_1 + c_2 E_2 u_2 + ... + c_n E_n u_n
we also have
E_k w = c_1 E_k u_1 + c_2 E_k u_2 + ... + c_n E_k u_n .
Subtracting one from the other, we get
c_1 (E_k - E_1) u_1 + c_2 (E_k - E_2) u_2 + ...+ c_(k-1) (E_k - E_(k-1)) u_(k-1) + c_(k+1) (E_k - E_(k+1)) u_(k+1) + ... + c_n (E_k - E_n) u_n = 0 .
Since the u_j's are linearly independent, the coefficients must all be zero. But the eigenvalues are distinct, so this means that all the c_i's are zero except for c_k. In other words, w = c_k u_k, and is thus proportional to the original eigenvector u_k.
In my case, I do not have degenerate eigenvalues. So, I guess that means my eigenvalues in H are distinct?
My problem is if H is very close to diagonal before I numerically diagonalize it, I expect the numerical diagonalization to give me a V that is close to the identity matrix. More importantly, I expect the V calculated when H is close to diagonal to not affect X at all. That is,
Vadj X V -> X
What I find when H is close to diagonal is that the eigenvectors transform
X into X plus linear combinations of the commutators of X and B.
I suppose I could adjust the phase of each column in V so I have ones on the diagonal. That should still give me a V that diagonalizes H.
Oops. I goofed when I said
me said:
In this case, the only difference... Therefore Voadj X Vo = Vadj X V.
That equation isn't true.
You are right about the commutators of X and B appearing in your expression for Voadj X Vo. Here's why. Suppose, like you said, that V is almost the identity matrix. Then we can write it as
V = 1 + i \epsilon U
where epsilon is a small parameter. V is unitary, which gives a condition on U:
VV^\dagger = (1+i\epsilon U)(1-i\epsilon U^\dagger) = 1 + i \epsilon (U - U^\dagger) + O(\epsilon^2) .
For V to be unitary, we must have that U = U^\dagger to first order in epsilon.
Then
V^\dagger X V = X + i\epsilon [X, U] + O(\epsilon^2)
Now if V_o = V e^{i B} where [B, D] = 0, we get
V_o^\dagger X V_o = e^{-iB}Xe^{iB} + i\epsilon e^{-iB}[X, U]e^{iB} + O(\epsilon^2)
But e^{-iB}Xe^{iB} = X - i[B, X] - \frac{1}{2}[B, [B, X]] + ...
And that expansion is what you get for VoadjXVo to zeroth order in epsilon. Or I guess I should say, I think that is what you get. Does it agree with your result?
Yes, you understand my problem. Your previous post, however, made me realize that the solution is quite simple.
I just adjust the phase of each eigenvector column in V so its diagonal elements are real. This doesn't affect the diagonalization of H (since it's an unobservable phase), and it puts my numerical V in a form that will match my perturbation expansion for it, namely,
V = 1 + V(1) + V(2) + ...
Not only does it give me the correct Ix matrix in the zeroth order limit, but the code seems to converge to the right signal with much larger dt steps.
I'm happy. :smile:
I'm a little surprised I could find any discussion like this elsewhere on the web. Hopefully, this thread will be helpful to someone else in the future.
Thanks for your help.
Phil G <- that me - pjg
That's great! Good work! So you are writing your own eigensolver?
No, I just translated the EISPACK routines used in CH from fortran into C, and use that. It works well, and I don't have to worry about someone struggling to get the code compiled and linked to libraries.
Here's the snippet of code I wrote to solve the problem...
ch(Ham,eig,V,1,nstate,scratch,scr_cvec,scr_dvec);
for(r=1;r<=nstate;r++) {
Ax = V[r][r].r;
Ay = V[r][r].i;
norm = sqrt(Ax*Ax + Ay*Ay);
element.r = Ax/norm;
element.i = -Ay/norm;
for(s=1;s<=nstate;s++) {
V[r].r = element.r*V[r].r - element.i*V[r].i;
V.i = element.i*V[r].r + element.r*V[r].i;
Okay, cool. I'm not familiar with CH. What is it?
Thank you! :smile:
There's was a mistake in my previous post. The fix should have been
V_r = V[r];
Ax = V_r[r].r;
Ay = V_r[r].i;
Ax = Ax/norm;
Ay = Ay/norm;
element.r = V_r.r*Ax + V_r.i*Ay;
element.i = V_r.i*Ax - V_r.r*Ay;
V_r.r = element.r;
V_r.i = element.i;
  • · Replies 33 ·
  • · Replies 52 ·
  • · Replies 40 ·
