Finding kinetic energy between parallel plates
An electron accelerated through a potential difference of 600 V between two parallel plates gains kinetic energy calculated using the formula K.E. = qV, where q is the charge of the electron (approximately 1.6 x 10^-19 C). The kinetic energy gained by the electron is 9.6 x 10^-17 J, derived from multiplying the voltage difference (600 V) by the charge of the electron. The discussion clarifies that electric potential difference directly correlates with the conversion of potential energy to kinetic energy.
  • Understanding of electric potential difference
  • Knowledge of kinetic energy formulas
  • Familiarity with the charge of an electron (1.6 x 10^-19 C)
  • Basic principles of conservation of energy
  • Study the relationship between electric potential and kinetic energy in charged particles
  • Learn about the conservation of energy in electric fields
  • Explore calculations involving electric potential energy differences
  • Investigate the behavior of electrons in electric fields
Students in physics, electrical engineers, and anyone interested in understanding the dynamics of charged particles in electric fields.
mirandab17
An electron, initially at rest, is accelerated through a potential difference of 600 V between two parallel plates.
The plate on the bottom is @ 0 V. The top plate is 600 V. And the distance between the two is 4.2 x 10^-2 m.
Calculate the kinetic energy gained.
Alright, so initially I was thinking the potential energy must be converted into kinetic energy, so I started using the conservation of energy formula and ended up with -U = Kf. Is electric potential difference the same as electric potential energy?
The answer's 9.6 x 10^-17 J btw. Can't figure out how!
You multiply the voltage difference times the charge to get the potential energy difference don't you? Sure, that would be the kinetic energy gained. I can't figure out why you aren't getting the right answer. Can you show your work?
  • · Replies 58 ·
