Finding Mass and Distance using apparent Weight
17 replies · 20K views · last reply
iHate Physics
Henry gets into an elevator on the 50th floor of a building and it begins moving at t=0s The figure shows his apparent weight over the next 12s.
http://img520.imageshack.us/img520/8404/knightfigure0530ry3.th.jpg
What is Henry's mass?
How far has Henry traveled at t =12s
F=ma
w=mg
weight apparent = w(1+ a/g)
Well so far, all I know is that the elevator is moving down since the apparent weight has gone up. I have no idea how to approach the problem and I have tried using the third formula that I have listed but no luck. Do I even use the apparent weight equation? Because I need the acceleration, and no information has been given on that.
Well the way I would read that, is that the elevator accelerates downard initially for 2 seconds, since Henry is lighter, then descends at constant speed (from which one can get Henry's weight), then decelerates (Henry is heavier), and then stops (from which one again get's Henry's weight).
One needs to determine when to apply W = m(g-a) and W = m(g+a).
Oh, I see, so you would you would use 750 N as his weight when determining the mass. Thanks for explaining the graph to me. Even our prof never explained this kinda graph to us. To me this is new material. k, Lemme try to find the distance now. I would need to find the acceleration first right?
ouch, ok nevermind... Anyone have any tips on how to approach this when finding distance?
For an approximation, one could assume constant acceleration.
Then there are three parts of the problem to find distance - the initial drop at constant acceleration, the descent at constant velocity, and the descent during deceleration.
See this reference - http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html
but wouldn't i need the velocity as well? i have acceleration as 1.962 m/s.
Start with an initial velocity of zero at t = 0s.
Use the acceleration to find the distance and velocity at t = 2s. That velocity is the initial velocity and constant velocity for the period t =2 s to t = 10 s.
Determine the distance for that period.
Then use that intial velocity and deceleration for the final period 10 s to 12 s, when velocity goes to zero because the elevator stops.
iHate Physics said:
Do i add all the distances up?
Sure, why not?
Argh, i don't know what I am doing wrong but the answer i keep getting is wrong. Is my acceleration correct?
About 1.96 m/s2 is correct. Here I'm assuming a step change in acceleration. From the curve, it looks like it changes rapidly from 1.96 to 0 between 2 and 2.2 s, so that could be a source of error, but it should be relatively small.
Please write out the formulas one is using.
ok well i got 62.784 m as the total distance traveled after 12 secs. Is that correct?
oh well I used the formula i mentioned in the beginning
Apparent Weight = mg(1+a/g)
Basically for t=0 to t=2 i got 3.924 m
t=2 to t=10 i got 31.392m
t=10 to t=12 i got 27.468m
and i got the total to be 62.784m
whoops i should start editing my posts instead of continuously posting. Sorry.
It seems you've done that part correctly.
Please write the formulas for distance and velocity at 2 s, and then at 10 s, and then at 12 s, so we can see how you determine the cumulative distance.
k well i did for
t=0 to t=2
x = (0)(2) +1/2 (1.962)(2)^2
x = 3.924m
Vf^2 = (0)^2 +2(1.962)(3.924)
Vf = 3.924
is that correct so far?
then for t = 2 to t = 10 Constant Velocity so a = 0
x = 3.924 (8) + 1/2 (0)(8)^2 Took t=8 since 10-2 = 8
x = 31.392m
then for t=10 to t=12
x = (3.924)(2) + 1/2 (-1.962)(2)^2
x = 3.924m
and the total i got was 39.24 m ( Realized i had an error in there so i changed it)
