Finding Max/Min Values on Functions of 2 Variables
  • Thread starter Thread starter TranscendArcu
    Functions Variables
12 replies · 3K views
TranscendArcu
Let g(x,y) = x2 + 4y2. What is the maximum value of F(x,y) = ln(x4y5) on the intersection of the level set g(x,y) = 9 with the quadrant {(x,y): x>0 and y>0}
It seems I'm having a lot of difficulty with Lagrange multipliers, but here I go.
Fx = 4/x = gx = 2x * λ
Fy = 5/y = gy = 8y * λ
Then clearly, x2 = 2/λ
and, y2 = 5/(8λ)
Plugging these into the constraint gives,
g(2/λ,5/(8λ)) = 4/λ2 + 4 * (25/(64 * λ2)) = 9.
Attempting to solve for λ gives,
(4/λ2) (1 + 25/64) = 9
4 + 25/16 = 9λ2
λ = ± √(4/9 + 25/144). But I reject the negative because it will yield answers outside the boundary
x = sqrt(2/λ) = sqrt(2/(sqrt((4/9 + 25/144))) ≈ 1.594990568
y = sqrt(5/(8λ) = sqrt(5/(8sqrt((4/9 + 25/144))) ≈ 0.89162683338
So I get an extremum at F(1.594990568,0.89162683338), whatever that is...
Pretty sure this isn't right. Ideas?
I find that it is often simplest to eliminate [itex]\lambda[/itex] (which is not necessary for the solultion) first by dividing one equation by another.\
Here, you have [itex]4/x= 2\lambda x[/itex] and [itex]5/y= 8\lambda y=[/itex]. dividing the first by the second gives (4/5)(y/x)= x/(4y) or 16y^2= 5x^2. [itex]y= \pm (\<br /> sqrt{5}/4)x[/itex]. Substitute that into the constraint and solve for x.
However, given the constraint y > 0, we would reject the negative answer for y = (sqrt5/4)x, right?
Supposing I solved out for x instead of y. I begin with 4y/(5x) = x/(4y), which gives 16y^2 = 5x^2. So,
x = 4y/sqrt(5)
Subbing into x^2 + 4y^2 = 9 gives (16y^2/5) + 20y^2/5 = 9. So, 36y^2 = 45, or
y = sqrt(45)/6 = sqrt(5)/2
By our definition of x in terms of y: x = 4(sqrt(5)/2)/sqrt(5) = 2.
Therefore, our maximum value is ln(16 * 5^(5/2)/4^5) = ln(5^(5/2)/64) and exists at (2,sqrt(5)/2)
Sound about right?
But given the constraint (x,y): x>0 and y>0, shouldn't be the cases of x=0 and y=0 be non-issues?
Suppose that at x=0.0001 your function would have a higher value than your "maximum"?
and, y2 = 5/(8λ)
4 + 25/16 = 9λ2
[itex]F_x[/itex] is not equal to [itex]4/x[/itex] , and [itex]F_x[/itex] is not equal to [itex]g_x[/itex], although later you set it equal to [itex]\lambda g_x,[/itex] which is OK. Start again, with correct derivatives for F, and be sure to write the Lagrange equations correctly.
RGV
Alright, so let me test the boundaries of the quadrant:
Suppose x = 0 and y ≥ 0, then ln(x4y5) goes to -∞. Right?
Suppose y = 0 and x ≥ 0, then ln(x4y5) also goes to -∞.
Hmm... Maybe I just don't know how to check a boundary. How do you check a boundary?
RGV
I checked Fx with Wolfram Alpha: http://www.wolframalpha.com/input/?i=d/dx+ln(x^4y^5)
What am I doing wrong?
You just did.
Note that your function won't have a global minimum, since for x or y close to zero it approaches minus infinity.
But the extremum that you did find, has to be a maximum now.
Sorry: your F_x is correct. I was thinking about using x^4*y^5, rather than its logarithm.
Anyway, your major error (besides saying F_x = g_x---which is FALSE) is that you have x^2 = 2/lambda, etc., so when you substitute these into g you should NOT get 1/lambda^2. You are substituting x^4 and y^4 into g, which is incorrect.
RGV
