Finding minimum force to slide steel block across table
7 replies · 4K views
physstudent1
This problem has to do with physics but it is from my calculus book, and for my calc class so I put it here:
"A component is designed to slide a block of steel with weight W across a table and into a chute. The motion of the block is resisted by a frictional force proportional to its apparent weight. (Let k be the constant of proportionality.) Find the minimum force F needed to slide the block and find the corresponding value of theta. (Hint: FcosTheta is the force in the direction of the motion, and FsinTheta is the amount of force tending to lift the block. So the apparent weight is W-Fsintheta.)"
Apparent weight = W-FsinTheta
I set the equation FcosTheta = k(w-Fsintheta)
I really don't know where to go from here. In every optimization problem we have found 2 equations a primary and a secondary and used the secondary to relate to get rid of variables. Can someone please point me in the right direction I'm pretty lost.
Think back to basic calculus, sketching graphs of function, etc. If you have an equation y = f(x), how do you find the value(s) of x where the maximum or minimum value(s) of y occur?
Here you have an equation with two variables F and Theta, and you want the minimum value of F.
the answer is F = kW/(sqrt(k^2 +1)) if that helps anyone (its in the back of the book) I'm really not sure how to get there
Your equation looks OK.
Do you know the answer to the question "how to find the min or max of a function y= f(x)" using calculus? If you drew a graph of a function y = f(x), what is the slope of the graph when y = a minimum or maximum? How do you find the slope of a graph?
When you do that, you will have another equation in F and Theta and you can solve the 2 equations.
yeah so I just take the derivative of my equation and set it equal to zero right? The only thing I'm not sure is what to set the equation equal to before I find the derivative should I make it F = (rest of equation).
I think my problem is in actually finding the derivative I get this for the derivative
F' = (-kw(-sinTheta+kcosTheta))/(cosTheta+ksinTheta)^2
Yes, take the derivative and set it equal to zero.
You can do it your way and write F = (rest of equation) if you want, but it's might be easier just to differentiate it as it is.
I'm going to write t for Theta 'cos I'm lazy :smile: so your equation was
F cos t = k(w - F sin t)
F cos t = kw - kF sin t
Differentiate with respect to t (remember k and w are constants)
Using the rule for differentiating a product of two functions f and g: d(f.g)/dt = f dg/dt + g df/dt
dF/dt cos t - F sin t = - k dF/ft sin t - kF cos t
At the minimun dF/dt = 0 so
- F sin t = - kF cos t
tan t = k
Actually your way gives the same answer: you have
-kw(-sinTheta+kcosTheta)/(cosTheta+ksinTheta)^2 = 0
Multiply both sides by (cos Theta + k sin Theta)^2
-kw(-sin Theta + k cos Theta) = 0
k and w are not = 0 so -sin Theta + k cos Theta = 0
tan theta = k
I see! That makes a lot of sense I thought about deriving it that way at first, I just didn't realize to plug 0 in for dF/dt. Thanks a lot! To get the Force I'm thinking I can plug in tan theta for k into the original equation, thanks for all the help.
You got it.
