Finding Minimum Thickness Problem
  • Thread starter Thread starter Maxamillion00
    Minimum Thickness
Maxamillion00
A polymer coating has a n=1.30 and a base of n=1.50. What is the minimum thickness of the coating to reflect 500 nm least strongly?
That is a pretty standard thin-films problem ... how have you attempted to solve it?
You have to show work first.
