Finding N for a sequence limit with absolute value inequality
9 replies · 2K views · last reply
kwal0203
Suppose [tex]a_{n}=\frac{n^2-2n+1}{2n^2+4n-1}[/tex]
For each positive number [tex]\epsilon[/tex], find a number N such that:
[tex]\mid a_{n} - L\mid < \epsilon[/tex] whenever n > N.
[tex]\mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1} {2} \mid < \epsilon[/tex]
[tex]\mid \frac{3-8n} {4n^2+8n-2} \mid < \epsilon[/tex]
Now I have no idea how to isolate the n so that I can find the N value. Any help appreciated.
Thanks!
For each positive number \epsilon, find a number N such that:
\mid a_{n} - L\mid < \epsilon whenever n > N.
\mid \frac{3-8n} {2n^2+4n-1} \mid < \epsilon
Thanks!
Try some estimating.
Can you fix your latex?
Fixed it up.
Estimating what exactly?
kwal0203 said:
Fixed it up.
Estimating is a technique, which no one seems to teach explicitly for evaluating limits. Let me give you an example and see if you can apply the idea to your case.
Show that ##5n^2 + 3n + 133## tends to ##\infty## an ##n \rightarrow \infty##
Estimating technique:
For ##n > 1## we have ##n^2 > n## hence ##5n^2 > n##. So:
##5n^2 + 3n + 133 > 4n + 133 > 4n > n##
Now, we can use a simple ##N## in the limit argument. Whereas, trying to find ##N## for the orginal quadratic would be messy.
kwal0203 said:
[tex]\mid \frac{3-8n} {2n^2+4n-1} \mid < \epsilon[/tex]
PS I think you've lost a factor of ##2## from the denominantor.
Yes I definitely have, thanks.
So it goes kinda likes this:
For n > 1 we have [tex]n^2>n[/tex] hence, [tex]2n^2>n[/tex] So:
[tex]2n^2+4n-1>5n-1>5n>n[/tex]
And in a similar way:
For n > 1 we have [tex]3 - 8n > 3 - 8 = -5[/tex] So:
[tex]\mid \frac{-5}{n} \mid < \epsilon[/tex]
and,
[tex]n > 5 / \epsilon[/tex]
Is that what you mean?
and,
First, you need to take that ##\epsilon## out of your working. That seems to be a common mistake to introduce ##\epsilon## into the inequality too soon. Second, your estimates have gone a bit wonky!
Let me show you what I mean. You should leave out the ##\epsilon## for now and do:
##\mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1} {2} \mid \ = \ \mid \frac{3-8n} {4n^2+8n-2} \mid \ < \ \mid \frac{8n} {4n^2+8n-2} \mid \ \dots##
Note that the numerator is less than ##8n## and you need an over-estimate on the numerator and an underestimate on the denominator. But, your underestimate on the denominator can't be too crude, because ##8n/n## doesn't converge to 0. So, you need an estimate based on ##n^2## in this case.
It's only when you've finished this algebra that you bring in ##\epsilon##. For example:
Let ##\epsilon > 0 ## and take ##N > 1/ \epsilon## (or whatever you think you need from your calculations). Then ##n > N## implies:
##\mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1}{2} \mid < \frac{1}{n} < \epsilon##
Ok I think I get it now. Thanks for your help I'll do some more work on it.
The simplest way to explain estimating is perhaps:
##|\frac{a(n)}{b(n)}| < |\frac{c(n)}{d(n)}|##
Where ##|a(n)| < |c(n)|## and ##|b(n)| > |d(n)|## and ##c(n), d(n)## are some simple expressions in ##n## that reduce to something that can easily be shown to have a limit of ##0##.
