Finding Net Force on a 725 Gram Block with Given Acceleration and Angle
4 replies · 3K views
ScienceGirl90
Find the magnitude of net force on the following object a 725 gram block that is accelerating at 8.10 m/s2 at an angle of 18.0 degree relative to horizontal.
F=m*a
I first converted the 725 grams to kilograms but then after that I am unsure of what to do. Having information about the angle is throwing me off because I don't know what equation to use.
Well I did read that if you know the direction of acceleration, you know the direction of the net force. But I am still confused as to how this helps. Would you please explain more? Thank you!
What you have to do is find your force for your x-component and your force for your y-component and then find the magnitude of these. because its asking for magnitude.
so..
F_x = ma_x
and
F_y = ma_y
so for these equations obviously your mass will be the same value, but you must find your x and y component of acceleration, which is an easy trig problem (draw a triangle)
you should be able to then easily solve for you F_x and F_y
once you find these you should know how to find the magnitude, its the square root of (F_x)^2 + (F_y)^2
