Finding object distance with converging lenses.
  • Thread starter Thread starter ilovedeathcab
    Converging Lenses
To find the object distance with a converging lens of focal length 33.7 cm and magnification -2, the relevant equations are 1/f = 1/do + 1/di and M = -di/do. The initial calculations led to confusion in adding fractions correctly, specifically when transitioning from 1/do + 1/2do. After correcting the fraction addition to 3/2do, the object distance can be solved accurately. The final object distance is determined to be 11.23 cm.
ilovedeathcab
A converging lens with f=33.7 cm yields an image with magnification M=−2. Find the object distance. Give your answer ...
* in terms of centimeters. Do not include units in your answer. They will be assumed to be cm.
I'm not really sure how to approach this problem. I keep calculating it and getting the wrong answer. I started with the 1/f =1/do + 1/di equation, and know that M = -di/do, but from there my work is probably wrong
-2=-di/do : -2do = -di ----> 2do=di
1/f=1/do + 1/2do
1/f =1/3do
f= 3do
1/3f=do
1/3 * 33.7cm =do
do= 11.23cm =WRONG.
Ok, your mistake is going from the 2nd line to the 3rd line.
You didn't add the fractions properly. What is 1+1/2?
I'm still confused... 1/f= 3/2do? i don't know where to go from there
Solve for 'do' since you know what 'f' is.
thanks! i got the right answer this time...
9K
