Finding P(X1<X2<X3) and P(X1=X2<X3)
  • Thread starter Thread starter cookiesyum
The discussion focuses on calculating the probabilities P(X1 < X2 < X3) and P(X1 = X2 < X3) using the joint probability density function (pdf) f(x1, x2, x3) = e^{-(x1+x2+x3)} for 0 < x1, x2, x3 < ∞. The correct setup for the triple integral to find P(X1 < X2 < X3) involves integrating with proper limits: x1 from 0 to ∞, x2 from x1 to ∞, and x3 from x2 to ∞, resulting in a probability of 1/6. The joint moment generating function (mgf) is also discussed, with the integral E(e^{t(x1+x2+x3)}) being simplified by using a single variable t instead of multiple t's.
  • Understanding of joint probability density functions (pdfs)
  • Knowledge of triple integrals in multivariable calculus
  • Familiarity with moment generating functions (mgfs)
  • Basic concepts of continuous random variables and their properties
  • Study the derivation of joint pdfs and their applications in probability theory
  • Learn about calculating probabilities using multiple integrals
  • Explore the properties and applications of moment generating functions (mgfs)
  • Investigate the implications of continuous distributions on probability calculations
Students and professionals in statistics, probability theory, and data science who are working with joint distributions and moment generating functions. This discussion is particularly beneficial for those tackling advanced probability problems in academic settings.
cookiesyum
Let f(x1, x2, x3) = e-(x1+x2+x3), 0<x1,2,3<infinity, zero elsewhere be a joint pdf of X1, X2, X3.
Compute P(X1< X2< X3) and P(X1= X2< X3)
Determine the joint mgf.
P(X1< X2< X3) = triple integral of e-(x1+x2+x3) dx2dx1dx3 as x2 goes from x1 to x3, x1 goes from 0 to x2 and x3 goes from x2 to infinity.
When I solve this integral I get 0 for an answer. The back of the book suggests the answer is 1/6. Clearly, I am setting up the problem wrong, but I don't know where my mistake is. Similarly, I'm having trouble setting up the second part of the question as well.
Joint mgf = E(et1x1+t2x2+t3x3) but this integral is not easy by hand. Is there another way to do it?
Yeah, your integration limits are incorrect. For P(x_1<x_2<x_3), start from x_1. Say it goes from zero to infinity. Then x_2 has to go from x_1 to infinity, and likewise x_3 goes from x_2 to infinity.
What's hard about solving the MGF?
E(e^{t(x_1+x_2+x_3)}) = \int dx_1 dx_2 dx_3 f(x_1,x_2,x_3) e^{t(x_1+x_2+x_3)} = \int dx_1 dx_2 dx_3 \exp [(t-1)(x_1+x_2+x_3)]
I'm sure you know how to integrate an exponential function.
Oh! I was doing it with three different t's ... t1 t2 and t3 which made it a million times harder. That makes sense. Thanks so much!
I guess you do need multiple t's. It doesn't make it any harder though.
No, you don't need multiple ts.
<br /> \phi(t)_{X_1+X_2+X_3} = \idotsint e^{t(x_1+x_2+x_3)} f(x_1,x_2,x_3)\,dx_1dx_2dx_3<br />
Aren't your variables independent exponentials?
Yep, finally got the answer. Thank you everybody for your help!
What about P(X1=X2<X3)?
The random variables are drawn from a continuous distribution, and are independent. Do you know what the probability is that a continuous random variable will be exactly some specified number?
zero, it must be an interval... So then would it be P(X1=X2<X3) = P(X1<X3)*P(X2<X3) or even P(0<X3)?
You are correct that this is the joint mgf (with three different t's). If you had t1 = t2 = t3 = t, as some others have suggested, you would be finding the mgf of the single random variable X = X1 + X2 + X3. Anyway, the integral is *very easy* by hand.
RGV
RGV
I have a question about the mgf...
So this is the integral that we need to integrate, right?
\int_0^{\infty} \int_0^{\infty} \int_0^{\infty} e^{x_1(t_1-1)} e^{x_2(t_2-1)} e^{x_3(t_3-1)} dx_1 dx_2 dx_3
But I'm having some trouble with this, because this is what I get after integrating...
\frac{1}{t_1-1}e^{x_1(t_1-1)} |_0^{\infty} \frac{1}{t_2-1}e^{x_2(t_2-1)} |_0^{\infty} \frac{1}{t_3-1}e^{x_3(t_3-1)} |_0^{\infty}...but if we plug in infinity to \frac{1}{t_1-1}e^{\infty(t_1-1)}...don't we get infinity, since e increases forever?
That depends on whether t-1 is positive or negative.
Thanks a lot...
