Finding points on curve where tangent line given
10 replies · 3K views · last reply
TsAmE
Find all points on the curve x^2 * y^2 + xy = 2 where the slope of the tangent line is -1.
y' = -1
I got the y' = [ -2xy^2 - y ] / [ 2x^(2)y + x ] to be the gradient which I am sure is right.
Then I subbed in y' = -1 and tried to solve for y, where I reached the line -2x^(2)y + 2xy^(2) + y = x. Is there a way to factor out the y?
y' = -1
I'll take your word that your derivative is correct.
Since the slope is -1, you have
-1 = [ -2xy^2 - y ] / [ 2x^(2)y + x ], which implies that 2xy^2 + y = 2yx^2 + x, or equivalently, 2xy^2 + y - 2yx^2 - x = 0.
This can be factored.
Oh I see. I got to:
( 2xy + 1)( y - x ) = 0
y = - 1 / 2x OR y = x
subbed it back into the original equation and for the y = -1 / 2x I got x^2(-1 / 2x)^2 + x(-1 / 2x) = 2 which simplifies to (1 / 4) - 2 = 2 and for y = x I got x^(2)(x)^2 + x(x) = 2 which simplified to x^(2)(x^(2) + 1) = 2 and I can't solve for any of the x values :(
If y = x, then the original equation can be written as x^4 + x^2 - 2 = 0. This is quadratic in form and can be factored into two real solutions and two imaginary solutions.
If y = -1/(2x), the original equation can be written as x^2/(4x^2) - x/(2x) = 0, or 1/4 - 1 = 0, which is impossible.
For it x^(2) (x^2 + 1) =2 don't you get x = +/- (2)^1/2 OR x = +/- (2-1)^1/2?
I got 1/4 - 1/2 = 2 as there is a 2 or the RHS of x^2/(4x^2) - x/(2x) = 2
This isn't how factoring works. If a*b = 2, there are an infinite number of possibilities for a and b. However, if a*b = 0, then you can say for sure that a = 0 or b = 0.
Factor the left side of x^4 + x^2 - 2 = 0 into two binomials.
Yes, you get 1/4 - 1/2 = 2, not 1/4 - 1/2 = 0 as I said. Either way, there are no solutions when y = -1/(2x).
Oh ok I got that. Now my final answer was (1, -2) and (1, 1) and also (-1, 2) and (-1, 1), yet the answer at the back of the book only said (1, 1) and (-1, 1). :confused:
It goes back to what I said in post 4.
This assumption here is that y = x. From that you get x^4 + x^2 - 2 = 0, so x = 1 or x = -1. Since by assumption y = x, then the points where y' = -1 are at (1, 1) and (-1, -1). I checked both of these against your derivative function and got -1 at both. Are you sure you book has (-1, +1) as one of the two points?
Sorry yeah you right it (-1, -1) made a typing error. I looked at your 4th post but still not sure as I used the two real solutions (x = -1 and x = 1) and subbed them back into the original equation to get a quadratic for y on both occasions, which is why I have to 4 different points as opposed to the correct 2. It seems defined to me when I subbed the (1, -2) and the (1, 1) back into the equation which gave 2 = 2, which is true.
When you set the derivative equal to -1, there were two cases: y = x and y = -1/(2x), the latter of which can't happen.
Assuming y = x, you solved the equation x^4 + x^2 - 2 = 0, and found that x = 1 or x = -1.
If x = 1, y = 1. If x = -1, y = -1. Period. These are the only two points on the graph of (xy)^2 + xy = 2 at which the derivative equals -1.
Your mistake seems to be that you substituted (1, -2) and whatever the other point happens to be, into the original equation and got a true statement. All that says is that (1, -2) is a point on that curve. If you substitute this point into the derivative expression, you won't get -1.
