Finding Product of Complex Polynomial Roots
14 replies · 3K views · last reply
cdummie
It is known that roots of complex polynomial:
##P_n (z) = z^n + a_{n-1}z^{n-1} + \cdots + a_1z + a_0##
are the following complex numbers:
##\alpha_1, \alpha_2, \cdots, \alpha_n ##
Find the product:
##\prod = (\alpha_1 + 1)(\alpha_2 + 1)\cdots(\alpha_n +1)##
I am pretty sure that i have to use Vieta formulas somehow, and since roots are all complex then it means that there are n/2 pairs of complex-complex conjugate roots. If i multiply all of this i would end up with product of all roots ##\alpha_1* \alpha_2* \cdots* \alpha_n ## and by Vieta formulas i can easily determine that one, but there are more elements of this product after multiplying, what can i do with them?
Ok so it has ##n## roots without counting multiplicity.
So your polynomial has the form ##P_n(z) = A(z) (z-\alpha_1)...(z-\alpha_n) ##.
Explain why ##A = 1##
Find the product:
This is only true if all coefficients are real numbers but you said "complex polynomial" which means that is not necessarily true.
Find the product:
The requirement of having complex-conjugate root pairs is true only if all the coefficients are real, and can fail if some of the coefficients are non-real complex numbers. For example, the equation ##x^2 + (2+i)x - 3 i = 0## has roots ##\alpha_1 \doteq 0.522 +0.788\, i## and ##\alpha_2 \doteq -2.552 - 1.788\, i ##.
I am not really sure, is it maybe because i have coefficient 1 with zn?
yes, but if you want to convince yourself, you can justify that ## \text{deg}{(A)} = 0##, so that ##A## is a non-zero constant, and with your argument above, ##A = 1##.
Ok, so now you have the answer, what is ##P_n(-1)## ?
Well, it's ## P_n(-1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0##
But how this gets me any closer to the solution?
You must have worked on this problem for too long :-)
Think about it 10 more minutes
EDIT: or don't think about it the next 10 minutes :-)
EDIT (+10 minutes) : What did we just say ? ##P_n(z) = (z-\alpha_1)...(z-\alpha_n)##. So what is ##P_n(-1)##?
I am sorry, i really don't know anything than this ## P_n(-1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0## which is obvious and it still isn't clear to me how this is going to help me solving this.
Does this formula (up to a possible sign) express your desired product in terms of the coefficients ##a_0, a_1, \ldots, a_{n-1}##? Did the problem ask you to do more than that?
I really don't understand what are you trying to say, do you mean that ##a_0 + a_1 + \ldots + a_{n-1} = \prod = (\alpha_1 + 1)(\alpha_2 + 1)\cdots(\alpha_n +1) ##?
You know that ## P_n(-1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0##.
You also know another way to find ## P_n(-1)##:
Now put the two together.
No, absolutely not. YOU said that ## P_n(-1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0 ## (not ##\sum a_j##). My question amounts to asking: why do you want to compute ##P_n(-1)##? What do you gain by doing that? How is that related to the product you started with?
You also know another way to find ## P_n(-1)##:Now put the two together.
Let's see: I have ## P_n(-1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0## and ## P_n(-1) =(-1-\alpha_1) \cdots(-1-\alpha_n)##
Now, taking all -1's out i have ##P_n(-1) =(-1)^n(\alpha_1+1) \cdots(\alpha_n+1) = (-1)^n + a_{n-1}(-1)^{n-1} + \cdots + a_1(-1) + a_0##
Multiplying both sides by ##(-1)^{-n}## i have:
##(\alpha_1+1) \cdots(\alpha_n+1) = 1 + a_{n-1}(-1)^{-1} + \cdots + a_1(-1)^{1-n} + a_0(-1)^{-n}##
Now, if this is correct i have another question, my idea was to use Vieta's formulas, i mean i have a given product which i have to find:
##\prod=(\alpha_1 + 1)\cdots(\alpha_n+1)## i am sure that there would be ##\alpha_1\alpha_2\cdots\alpha_n## but what is with rest of it , i mean i would have 1 at the end, but in order to use Vieta's formulas i should get something like ##\alpha_1\alpha_2 + \alpha_1\alpha_3 + \cdots + \alpha_1\alpha_n + + \alpha_2\alpha_3 + \alpha_2\alpha_4 +\cdots + \alpha_{n-1}\alpha_n## and then sum of products of three and so on all the way to the product of all of them. Is this correct?
Correct.
Using Vieta's formulas should also work, as you indeed get all possible combinations of products of roots when you expand ##\prod(\alpha_1 + 1)\cdots(\alpha_n+1)##.
