Finding refractive index by interpolation
5 replies · 5K views
Chen
The problem is described here:
http://phstudy.technion.ac.il/~wn117066/Problems2.pdf
In question 1 I need to find the refractive indices for both polarizations at 760nm. I'm not quite sure how to go about this - which model of dispersion best fits Calomel?
(I'm done with the exercise itself, now I just need to plug in the refractive indices values to get a numerical result...)
Thanks,
Chen
Interpolation is the process of estimating a value from a discrete set of ordered pairs of data. You could use a linear interpolation, or since you have three rather widely spaced points you could use a second degree polynomial (parabola) to fit the data and extract the interpolated data point. Most graphing calculators have a built in fitting program for this, probably called a quadratic regression. Or you could derive the equation from the three data points you are given and use it to find the additional popint you need.
http://en.wikipedia.org/wiki/Interpolation
I'm well familiar with the definition of interpolation, thank you.
physics girl phd said:
Or you could fit the data to find the sellmeier coefficients:
http://en.wikipedia.org/wiki/Sellmeier_equation
I considered that route, but having only 3 data points available makes it a bit hard to find those coefficients...
You could also use other models with fewer coefficients -- since yeah, you only have three points and probably don't want to trucate the Sellmeier series approach by too much (sorry I didn't notice that :rolleyes:):
http://www.optics.arizona.edu/Palmer/cgi-bin/index/dispeqns.pdf
The Cauchy model is common.
Thanks, that seems sensible. I'll report back if anything goes awry...
