Finding resistance from voltage and current measurements
11 replies · 5K views · last reply
bambilmiller
1. Write the equation for each run in the form (potential=constant x current)
{the form has two numerical list to work with}
2. How do I find the constant from these 2 lists? Is it the correlation that the question is looking for? or, Is it OHMs constant, that the question is talking about??
Hi bambilmiller and welcome to PF.
If I asked you to state Ohm's Law, what would you say?
It is the relationship among voltage, current and resistance. Where the current in a circuit is directly proportional to the voltage established across the circuit and is inversly proportional to the resistance of the circuit. I=V/R
Correct. Now can you answer question 1 and write the equation?
For question 2, look at your list. It has two columns of numbers. What are the symbols corresponding to the numbers that you know? Can you find an equation expressing the symbol that you don't know in terms of the symbols that you do know? If so, can you plug in numbers to find the unknown in terms of the known quantities for each line of your list?
That still does not answer my question. What is the constant? How do I figure out what it is?
I told you how to figure it out. If you answer my questions first (there are three of them, please answer them in order), you will be led to the answer of your question.
You could draw a graph for each table and see if you get a straight line. If so you might be able to see it is the same as y = 5x or y= 10x graph, or similar.
Is the correct equation for the first part V=IR ?
Thank you everyone for all your help. The light bulb just went off! :)
