Finding resultant force and direction from two forces on a car
  • Thread starter Thread starter delfam
    Angle Vector
4 replies · 2K views · last reply
delfam
two forces, 406N at 17 degrees and 256N at -26 degrees are applied to a a 3400kg car. Find resultant of these two forces and the direction of the resultant force between -180 and 180 degrees.
406cos(17) = 388.26, 256cos(26) = 230.09, 230.09 = 388.26 = 618.35N
arctan(230.09/388.26) = 30.65 degrees
because it's a car and it doesn't move on the y-axis. I'm still not sure how to get the angle though.
The car has nothing to do with anything. And changing -26 degrees to 26 was a nice trick, but you need to follow the rules because the next step requires the actual angle.
Does your answer make sense that the highest forces pulling at 17 degrees somehow generates a force vector that is 30 degress? Your answer is obviously somewhere between (17+26)/2=21.5 degree spread between the two forces. You have 1.58 times the force at 17 degrees than at -26 degrees, so you should be slightly higher off a midpoint mark (17-21.5 = -4.5 deg). So your answer should be above 0 degree mark at least, but not at 30 degrees! Your feasible region is thus between (-4.5, 17) degrees
Look at it this way.. if 17 degree force has (406/256)= 1.5859375 times more weight than the negative force, then your resultant should be around 1.5859375*17 + 1*(-26) ~ 0.96 degrees. Or more closely to the answer now, 1*17 + 0.60591138*(-26) ~ 0.60 degrees
You need to calculate all resultant forces and follow rules of trigonometry.
