Finding shearing force and moment
The discussion focuses on understanding the calculation of shearing forces and moments in a beam under load. The author explains that the distance for the 129 kN force is represented as x-2 due to the origin being at x=0, affecting the moment arm calculations. It is clarified that the shear force remains at 49 kN at x=6 because there are no additional loads affecting it, and the shear force values are cumulative, leading to sudden jumps at points where concentrated loads are applied. The discussion also emphasizes that the shear force diagram illustrates these jumps, which correspond to the magnitude of the concentrated forces. Overall, the concepts of shear force and bending moment are linked to their integral relationships with the load curve.
foo9008
i couldn't understand why the author take the distance of force 129kN for 4<x<6 and 6<x<8 is x-2 ?
IMO , for 4<x<6 , the distance of force 129kN to the point should be x , where x is the distance from the 129kN to the point of moment , correct me if i am wrong [/B]
is the author wrong ?
The black dot on the left end of the x-axis is the origin (x=0), so the moment arm from x (the point about which the moment is being calculated) to the 192kN force is x-2.
one more thing , why at x = 6 , the shearing force is still 49kN as in the calculation ? why shouldn't it be = 0 ?
why at x = 2 , there are 2 values of shearing forces , namely -40kN (0<x<2) and 89kN (2<x<4) ?
Because the reaction RA is located at x = 2. As you move along the beam from left to right, the shear force has a sudden jump from V = -40 kN to V = 89 kN, as the reaction RA = 129 kN is added.
Why should the shear be zero at x = 6?
The shear force and the bending moment values are each cumulative starting at the left end of the beam. If there is no additional load applied to the beam, the shear force at a particular point will not be changed.
sudden jump means there are 2 values of RA at x =2 ? why ?
can you explain why The shear force and the bending moment values are each cumulative starting at the left end of the beam.??
Because they are each integrals. The shear force is the integral of the load curve w.r.t. length, and the bending moment is the integral of the shear curve, also w.r.t. length.
The following slides explain this in more detail:
http://www.ce.memphis.edu/3121/notes/notes_04c.pdf
No, there is only one value of RA, namely RA = 129 kN.
The shear force diagram is a plot of just the shear force values acting on the beam. When a concentrated load is encountered, such as one of the beam reactions or an applied load, the shear force diagram will show a jump discontinuity at that location. The size of the discontinuity = the magnitude on the concentrated force.
Likes foo9008
This is an example shear force and bending moment diagram for a simple beam. It is plotted in its entirety so that you can look at the entire diagram at once, and not a series of confusing snippets:
11K
