Finding solenoid length given winding density and diameter
  • Thread starter Thread starter yaro99
    Length Solenoid
5 replies · 9K views · last reply
yaro99
(a) What would have to be the self-inductance of a solenoid for it to store 9.3 J of energy when a 1.56-A current runs through it?
(b) If this solenoid's cross-sectional diameter is 3.85 cm, and if you could wrap its coils to a density of 10 coils/mm, how long would the solenoid be?
l=D*N
D=π*d
I solved part a, I am only having trouble with part b.
The problem is, I only have the diameter, but I don't have N, the number of coils.
Here's how I tried to get N:
coils/m = 10/1*10^-3 = 10000 coils/m
then,
N = (10000 coils/m) * (0.0385 m) = 385 coils
then,
l = pi*(0.0385 m) * 385 coils = 46.57m
0.0385m is the diameter - are there 10000coils per meter across the diameter?! Usually the coils are across the length aren't they?
You are close:
If n=#turns per unit length, and N is the number of turns in the solenoid, and L is the length of the solenoid, then n=N/L
You have a formula for the inductance in terms of the L and N don't you?
So use some algebra to express it in terms of n and L.
You are close:
I got 7.643H for the inductance from part a
So if n=N/L, then N=n*L:
N = (10/(1*10^-3)) * 7.643 = 76430 turns
then,
l = pi*0.0385 * 76430 = 9244 m
It this correct?
... um... no: not what I wrote.
me said:
If n=#turns per unit length, and N is the number of turns[/color] in the solenoid, and L is the length of the solenoid, then n=N/L
Hmmm... L was not a good choice for a variable-name for length was it?
You pick one.
You are close:
Actually I don't. I couldn't find one in my book, but searching online I believe I found it:
L = μ0*A*l*n2
rearranging it gives:
l = L/(μ0*A*n2)
So,
l = (7.643)/([4*π*10^-7]*[π*(0.0385/2)2]*100002) = 52.24m
Is this right?
... hmmm, it's usually the first thing they do right after the Biot-Savart law. As in these utex lecture notes eq.909.
"Self Inductance" doesn't mean much without it.
Oh well...
You got the formula in the end.
Code:
> 7.643/((4*pi*10^-7)*(pi*(0.0385/2)^2) *(10000^2))
ans =  52.245
... which is rather long so probably impractical.
