Finding spring constant of bumper
7 replies · 10K views
mohamud3917
Today's cars have elastic bumpers that are designed to compress and rebound without any physical damage at speeds below about 5 mi/h (8 km/h). The material of the bumpers behaves essentially as an ideal spring up to that point but permanently deforms beyond that. If the compression corresponding to the elastic limit for a particular bumper is 1.6 cm, what must be the effective spring constant of the bumper material, assuming the car has a mass of 1070 kg and is tested by ramming into a solid wall
when i tried the k=mg/x
i got k=(1070kg)(9.8)/(0.016m)
so k=655375n/m
but it says its wrong
energy? i am really confused, can you please give me a step by step
thanks
What you did was find the spring constant needed to stretch 1.6cm if the car where hung from such a spring. But that's not what's going on here. The car has kinetic energy, which must be absorbed by the spring.
How do you find the spring potential energy of a compressed spring?
PEs=1/2kx2
PEs=1/2(655375n/m)(0.0162m)
PEs=83.888
so what is next
mohamud3917 said:
PEs=1/2kx2
This is the right formula for spring PE. Good!
This is incorrect. Remember you are solving for the spring constant. (Your calculation from your first post was wrong--otherwise you'd be done.)
You need to set the initial KE equal to the spring PE and solve for the spring constant.
ok so how do i find the potential energy of the spring, is it mgh?
mgh is gravitational PE, which is not relevant here. You gave the correct expression for spring PE in post #5.
