Finding Taylor series for x^3 at a = -1
The Taylor series for the function f(x) = x^3 centered at a = -1 is derived using the formula for Taylor series expansion. The correct coefficients are calculated from the derivatives evaluated at a = -1: f(-1) = -1, f'(-1) = 3, f''(-1) = -6, and f'''(-1) = 6. The final Taylor series expansion is -1 + 3(x + 1) - 3(x + 1)^2 + (x + 1)^3. The initial attempt incorrectly cubed the first and second derivatives, leading to an incorrect series.
  • Understanding of Taylor series expansion
  • Knowledge of derivatives and their evaluation at specific points
  • Familiarity with polynomial functions
  • Basic algebraic manipulation skills
  • Study the derivation of Taylor series for different functions
  • Learn about the convergence of Taylor series
  • Explore the application of Taylor series in approximating functions
  • Investigate the relationship between Taylor series and Maclaurin series
Students studying calculus, particularly those focusing on series expansions, mathematicians, and educators seeking to understand or teach the concept of Taylor series.
mcdowellmg
Find the Taylor series for f(x) centered at the given value of a. (Assume that f has a power series expansion. Do not show that Rn(x)--> 0.)
f(x) = x^3, a = -1
f(x) = f(a)+f'(a)(x-a)+(f''(a)/2!)(x-a)^2+(f'''(a)/3!)(x-a)^3+...+(f(nth derivative)(a)/n!)(x-a)^n
I found the following derivatives of x^3:
first: 3x^2
second: 6x
third: 6
fourth: 0
Then, I substituted: x^3 = (-1)^3+3^3(x+1)+(-6^3/2!)(x+1)^2+(6/3!)(x+1)^3+0
I reduced to -1-3(x+1)-6(x+1)^2+(x+1)^3, but WebAssign says that is wrong...
am I missing something here?
f(x) = x^3, a = -1
first: 3x^2
second: 6x
third: 6
fourth: 0
You have listed f(x), f'(x), f''(x), f'''(x) but I don't see your correct values for
f(-1), f'(-1),f''(-1),f'''(-1)
which you should be using for coefficients.
You can check your work by graphing the result & comparing the result with a graph of x3.
f(x) = x^3, a = -1
first: 3x^2
second: 6x
third: 6
fourth: 0
So f'(-1)= 3, f''(-1)= 6(-1)= -6, f'''(-1)= 6. But did you cube f' and f''?
The simplest way to get this is to let y= x+ 1. Then x= y- 1 and x^3= (y- 1)^3. Multiply that out and then replace y with x+ 1.
Thanks! I did cube f' and f'' for some reason. I ended up with -1+3(x+1)-3(x+1)^2+(x+1)^3, which was correct.
  • · Replies 27 ·
