Finding Tension T1 in a Pulley System
14 replies · 13K views · last reply
emilyb1995
A pulley is massless and frictionless. The
masses 2 kg, 3 kg, and 6 kg are suspended as
in the figure.
(Figure Attached)
What is the tension T1 in the string be-
tween the two blocks on the left-hand side
of the pulley? The acceleration of gravity is
9.8 m/s2 .
Answer in units of N
I'm completely stupped and have no clue where to begin. Just a hint on where to begin would be appreciated.
you should start by drawing a free-body diagram for each mass
It would just be Fg and Ft acting on each mass, correct?
well, yeah. The only forces here are the force of gravity on each mass and the force due to the strings on each of them
if you write down the net force for each of them then you should be able to see where to go from there
I write them down like this: (I'm going to tall the 6k mass m1)
F1 = m1g - T3
it's important to make sure the signs of each force are correct. I am setting downwards to be the positive direction.
(to get the little subscripts you can use the X2 button in the second row of the list of buttons in the post editor thingy)
Okay. So, if the 3kg mass is m2 and the 2kg mass is m3:
F2=T2-m2g
and
F3=T1-m3g
Are those correct?
Everything plugged in would be:
F1=6a=58.8-T3
F2=3a=T2-29.4
F3=2a=T1-19.6
F2=T2-m2g
and
F3=T1-m3g
Are those correct?
F1=6a=58.8-T3
F2=3a=T2-29.4
F3=2a=T1-19.6
well, really, at this point you don't want to plug anything in just yet. Oftentimes I find it easier to go through a physics problem with just the variables; it makes things less complicated when I write it down, and I know exactly where everything is, in case I need to do some algebra to it. also, I would reexamine the forces acting on the 3kg mass, m2
and then finally, of course, we're going to need the net force on the entire system, which is simply Fnet = (m1 + m2 + m3)a
That makes sense. So, with the 3k force, would it be
F2=T2-(m2g+m3g) ?
And if so, how would I solve for T1?
F2=T2-(m2g+m3g) ?
Well, it's actually a bit simpler than that. If you just look at the 3kg mass, there should be three forces acting on it. You got gravity and the 2nd tension force, but there's one more.
emilyb1995 said:
Would T1 be acting on it as well?
yep, so now you have four equations, right? One for the force acting on each mass, and one for the net force on the system. Don't forget that the net force acting on any object or system is just the sum of the forces acting on it.
Hmmm. You lost me. Would the system's Net Force equation just be m1g-T3+T2-T1-m2g+T1-m3g
it's just F1 + F2 + F3
those are the three forces acting on the system, so we just add them together to get the total. You should find that the tension forces all cancel out (pay close attention to how T2 and T3 relate to each other if you don't see why they cancel out).
Because the masses are suspended, would F2+F3=F1?
P.S. Sorry for all the questions, I'm having some trouble wrapping my head around it.
That would be true if the system were not moving. However, one side of the pulley has more mass than the other side. Common sense tells us that the side with more mass will go downwards, while the side with less mass will move upwards. So we know that the total force on the system can't be zero, because the masses are unbalanced.
So, there are three parts to this system. And to get the sum of the forces acting on the system, you just add up all the forces acting on each part of the system.
We're doing this because we don't know the total acceleration of the system. We need that to figure out T1. We know that all we need is a, because in the equation for F3, the only unknown quantity besides T1 is a.
it's m3 = T1 - m3g
so by determining a, we can determine T1 using that equation
to determine a, we need to find out what the total force acting on the system is. And since we have equations for each of the individual forces acting on the system we can just add them up to find the net force.
