Staff Emeritus
- 9
As some of you may already know, I have created a https://www.physicsforums.com/library.php?do=view_item&itemid=92" entry in the library as a complement to the PF History & PF Medals entries. The library entry explains what a 'Guru' is and also lists the current and past Gurus. After some digging around I have managed to locate lists of the majority of past Gurus; however I cannot find any record of the 2004 Gurus, nor can I find anything pre-2003 (I'm not even sure that we had Gurus before 2003).
So the first question is, does anyone know if we actually had any Gurus before 2003?
Secondly, does anyone know if there exists a record of the 2004 Gurus, and if so where is it?
If there is no record of the 2004 Gurus, then I propose that we do the following:
What do you Guys think?
- If any member knows who the 2004 Guru was for a particular category (e.g. Physics, Community Spirit etc.), then they should post their name, along with the proposed Guru category here (If you were a 2004 Guru, you should still 'nominate' yourself here).
- Other members would then be able to second or dispute the Guru 'nomination'.
- Once the 'nomination' has been seconded without being disputed, then the 'nominee' will be added to the list.
- Disputed 'nominations' will be discussed until a consensus is reached.
