Finding the Amplitude of a spring (Simple Harmonic Motion)
The discussion revolves around a physics problem involving a massless spring and a mass attached to it, focusing on simple harmonic motion (SHM). The original poster seeks to determine how far the mass descends, the frequency of the resulting SHM, and the amplitude of the motion.
  • Participants explore the relationship between gravitational force and spring force, considering conservation of energy to find the distance the mass descends. Questions arise regarding the setup of the problem and the definitions of kinetic, gravitational potential, and spring potential energies.
Some participants have provided insights into using conservation of energy to relate the different forms of energy in the system. There is ongoing exploration of how to correctly define and calculate the amplitude in relation to the distance fallen by the mass.
Participants note the importance of understanding the definitions of amplitude and the reference points for measuring it, as well as the need to clarify the initial and final energy states in the system.
Maxx573
[SOLVED] Finding the Amplitude of a spring (Simple Harmonic Motion)
First post here at PF, so forgive me if I make a faux pas. I'm trying to study for an upcoming Physics test and I'm having a bit of trouble with this.
A massless spring with spring constant 19 N/m hangs vertically. A body of mass 0.20 kg is attached to its free end and then released. Assume that the spring was un-stretched before the body was released. Find
a. How far below the initial position the body descends, and the
b. Frequency of the resulting SHM.
c. Amplitude of the resulting SHM.
[tex]a = -\omega^2x = \frac{d^2x}{dt^2} = -\frac{kx}{m}[/tex]
[tex]x = A\cos(\omega t+\phi)[/tex]
[tex]f = \frac{1}{T} = \frac{\omega}{2\pi}[/tex]
[tex]F = -kx[/tex]
[tex]F = ma[/tex]
I found (b), the frequency, since
[tex]f = \frac{\omega}{2\pi} = \frac{\sqrt{k/m}}{2\pi} = \frac{\sqrt{(19 N/m)/(0.2 kg)}}{2\pi} = \frac{\sqrt{95/s^2}}{2\pi} = \frac{\sqrt{95}}{2\pi s} \approx 1.551250 Hz[/tex]
However, I am having a hard time finding how far it will initially fall before coming back up. Once I have that, I could find the amplitude (or vice versa), I think. I know it will have to do with gravity, but I'm not sure how to set up this part of the problem.
Any help is appreciated. Thanks.
Hi Maxx573,
Try using conservation of energy to find how far it descends. What do you get?
Looking at the conservation of energy:
[tex]K = \frac{1}{2} kA^2\sin^2(\omega_0 t+\phi) = \frac{1}{2}mv^2[/tex]
[tex]U = \frac{1}{2} kA^2\cos^2(\omega_0 t+\phi) = \frac{1}{2}kx^2[/tex]
[tex]E = \frac{1}{2}kA^2 = \frac{1}{2}mv^2 + \frac{1}{2}kx^2[/tex]
OK, obviously something here should help me, but I just keep running into the same things. When [tex]U = E[/tex], then [tex]x = A[/tex] and [tex]v = 0[/tex]. When [tex]K = E[/tex], then [tex]a = 0[/tex] and [tex]t = 0[/tex]. Acceleration is at its maximum when all the energy is potential energy (and velocity is 0), and velocity is at its maximum when the spring is at equilibrium (and acceleration is 0).
All of this makes perfect sense to me, but I haven't been able to apply it to solving for [tex]A[/tex] or [tex]x[/tex] without already knowing one of them. I feel like the answer is staring me in the face, but I just can't find it.
In setting up this problem I would say there are three types of energies to keep track of: kinetic, gravitational potential, and spring potential. The two points you are interested in are the initial position, and the lowest point in the motion.
What is the kinetic, gravitational potential, and spring potential energies at the intial point? at the final point? Setting the total energy at the initial point equal to the total energy at the final point should give you the answer.
Ah, I think I've got it now.
So for the system's initial energy:
[tex]K = 0[/tex] (everything is at rest)
[tex]U_{spring} = \frac{1}{2}(19 N/m)(0)^2 = 0[/tex] (the initial position is 0)
[tex]U_{gravitational} = (0.2 kg)(9.8 \frac{m}{s^2})(x)[/tex]
(for this problem, I will refer to the lowest point as h=0, so initially h=x)
And the system's energy at the bottom of the bottom of the oscillation:
[tex]K = \frac{1}{2}m(0)^2 = 0[/tex] (velocity is 0)
[tex]U_{spring} = \frac{1}{2}(19 N/m)x^2[/tex]
[tex]U_{gravitational} = (0.2 kg)(9.8 \frac{m}{s^2})(0) = 0[/tex] (height is now 0)
[tex]E_0 = E_1[/tex]
[tex](0.2 kg)(9.8 \frac{m}{s^2})x = \frac{1}{2}(19 N/m)x^2[/tex]
[tex]1.96 N x = 9.5 (N/m) x^2[/tex]
[tex]1.96 N = 9.5 (N/m) x[/tex]
[tex]1.96m = 9.5x[/tex]
[tex]x \approx 0.2063158 m[/tex]
And since the mass starts from the point where the spring is neither compressed nor stretched, [tex]x = A[/tex]
That right?
That looks right to me.
This isn't quite right. Remember that x=0.206m is the distance from the highest to the lowest point of the oscillation. But where is the amplitude measured from?
Oh right. Amplitude is measured from the center of the oscillation to the highest (or lowest) point. So [tex]A = \frac{x}{2} \approx 0.103m[/tex]
Thanks a ton :)
Glad to help!
  • · Replies 51 ·
