What are the bounds of a ratio with a given set of numbers and variables?
The discussion focuses on determining the bounds of a ratio derived from a set of positive integers, specifically defined as ##\{r_i, r_{ii}, r_{iii}, ... , r_R\}##, where ##r_i \geq r_{i+1}##. Participants analyze the logarithmic expression ##log_2{\frac{(\sum_{i=1}^R{r_i})!}{\prod_{i=1}^R{(r_i!)}}}## and its relationship to the sum of the elements in the set. The conversation reveals that the ratio has not exceeded 1 in tested scenarios, leading to inquiries about the properties that influence its proximity to this value. The need for simplification and the exploration of maximum-minimum problems for two variables are also highlighted.
  • Understanding of combinatorial mathematics and factorials
  • Familiarity with logarithmic functions, specifically base 2
  • Knowledge of positive integer sequences and their properties
  • Basic concepts of optimization in mathematical functions
  • Explore the properties of logarithmic ratios in combinatorial contexts
  • Research optimization techniques for functions involving multiple variables
  • Study the implications of Stirling's approximation on factorial growth
  • Investigate the relationship between integer sequences and their bounds
Mathematicians, data scientists, and students studying combinatorial optimization or logarithmic functions will benefit from this discussion, particularly those interested in the behavior of ratios derived from integer sets.
iScience
Sorry in advance if I've posted in the wrong section.
given the set ##\{r_i, r_{ii}, r_{iii}, ... , r_R\}##
where ##r \ \epsilon \ \mathbb{Z}_+ \ , \ r_i \geq r_{i+1}##How would you go about finding the bounds of something like this, or determining if it even has any?
##( \, log_2{\frac{(\sum_{i=1}^R{r_i})!}{\prod_{i=1}^R{(r_i!)}}}) \, :\sum_{i=1}^{R}{i \cdot r_i}##
Since ##r_i## is the largest and ##r_R## is the smallest, the ratio in the log must smaller than ##\frac{(r_iR)!}{(r_R!)^R},## which may depend on ##r_i##, ##r_R## and ##R.## Does the problem require a fixed constant?
The fraction within the log is always greater than or equal to one, and only gets larger and larger with increasing ##R## and ##\bar{r}##. But I don't know how I would go about expressing the rate of change with respect to the denominator of the ratio.
Hmm, I guess... what I'm looking for is more of a simplification, because that would be easier to look at. But I'm not sure what you meant by the fixed constant thing, can you elaborate?
At first I'm not sure what you want also, and guess maybe you hope to get the ratio can be bounded with some cool number, maybe ##Ce^R##... likewise haha.
For me the fraction cannot be simplified XD
For any set of values I've tested so far, the ratio has not exceeded the value 1. In fact i haven't found it to ever reach 1. I wanted to know what properties of a given set determined its closeness to the value 1. I hope this makes sense.
What if I choose ##r_i=100,r_R=1,R=2?## Then the ratio is greater than 1 right?
##\{100\ ,\ 1\}## yields...
##numerator: log_2{ \frac{ 101! }{ 100! \cdot 1! } } = log_2{ \frac{ 101! }{ 100! } } = log_2{101} =7##
##ratio: \frac{7}{102} = 0.0686##
(remember the numerator is logged by base 2)
...My fault to miss the latter. I just saw the fraction. So the sum of ##r_x## is also concerned... Then it's harder to simplify...
I know I stated that simplification was my goal. But I suppose that's not the only way to achieve my "true goal", which I'm still getting closer to.. (sorry)
I postulate that there is a relationship between the numbers in the given set, that dictates its closeness to the value 1. I just want to figure that out..
even a pointer to how I might go about that would be of great help.
As matter of vocabulary, if we were "given" that set of numbers, the ratio would have a single numerical value, so when you mention "bounds" aren't we treating the ##R_i## as variables and asking how to maximize or minimize the ratio? Can we start by solving the max-min problem for 2 variables ?
  • · Replies 44 ·
  • · Replies 0 ·
