RJLiberator
- Messages
- 1,094
- Reaction score
- 63
Consider a disc (negligible thickness) of radius R with its center at the origin. Assume that the disc has a radially symmetric surface charge density given by ##σ(s) = \frac{A}{\sqrt{R^2-s^2}}## at a distance s from the origin, where A is some constant. You can take it for granted that this charge density leads to a potential that is constant everywhere on the surface of the disc, and hence, is suitable for describing the electrostatics of a conducting disc, and hence, find the capacitance of a conducting disc of radius R.
[Hint: In principle, the potential at any position on the disc can be calculated directly from the given charge density. Write down that expression for a general point which is at a distance r from the center. Note that since the charge distribution is cylindrically symmetric, so will V(r), which means you can place r along the x-axis in the (s, φ) polar coordinate system. You will realize that the integrations that you need to do are not trivial (do not attempt to perform the integrations for a general r, as their solutions involve elliptic functions). However, since you are given that the potential is constant anywhere on the disc, i.e. it is independent of r, it suffices to find the potential due to the given charge density at a special point on the disc, where the integrations are very easy to perform. This will allow you to relate the constant A to the potential V. Then you can find the total charge Q and relate Q and V to each other.
C = Q/V
##V = \frac{1}{4 \pi \epsilon_0} \int \frac{ \rho}{r}d \tau##
The Polar coordinate idea is killing me, I think.
But, we know what the charge distribution is, that's good.
The hint tells me to place r on the x axis... this means that in the integrations, ##r = \sqrt{s-s'}## for the distance between some point s and r?
Now, I think the idea from the hint is in the following set up:
[tex]V = \frac{1}{4 \pi \epsilon_0} \int_∞^s \int_0^{2 \pi} \frac{A}{\sqrt{R^2-s^2}} \frac{1}{\sqrt{(s-s')^2}} s dφds[/tex]
To let s' be some number that makes the integration simple compared to impossible to integrate regularly.
As far as the dφ integration goes, we simply get a 2pi out of it.
Am I setting this up correctly?
