Finding The Compression of a Spring
3 replies · 6K views
Astreiks
"A coil spring has a force constant of k = 4.0 lb/in. When the spring's axis is inclined at an angle 30 degrees from the horizontal, a W = 2.0 oz ball is propelled to a height of 6.0 ft. By how much must the spring have been compressed initially? (1 lb = 16 oz)
*PE = Potential Energy
*KE = Kinetic Energy
PEi = mgh
KEf = 0.5mv^2
F = ma
F = -kl
So, I set PEi = KEf
mgh = 0.5mv^2
v^2 = mgh / 0.5m
v = SQRT(2gh)
v = SQRT(2 * 32.2 ft/s^2 * 6 ft)
v = 19.7 ft/s
Now, I'm just really confused. I don't know how to go farther than this. I'm figuring that Vf = 0 ft/s (at the topmost point) but I don't know much more than that. I'm assuming that acceleration = gravitational constant, but I'm not really sure where that gets me. In the end, finding the velocity seems kind of useless. Unless you can just set F = ma = -kx, but I'm not sure whether I can actually do that, seeing how the spring is at an angle...
Someone tried to explain this to me and told me that I'm calculating this all wrong because I'm not taking into account horizontal vs. vertical PE and KE, so I'm even more utterly lost. Any help would be appreciated.
Your calculation of v looks ok, but you need to be clear exactly what speed this represents.
As a projectile rises, what happens to its horizontal velocity? What can you say about vertical and horizontal velocities at the highest point?
Depending on how hard the question is intended to be, there is a subtlety to be considered. It doesn't say whether the height is measured from the compressed position or the relaxed spring position. To keep it simple, assume the first option.
Use the energy theorem equation.
T=KE
V=PE
U=WORK
T1+V1+U=T2+V2
T=KE
V=PE
U=WORK
T1+V1+U=T2+V2
That will certainly be needed, but Astreiks isn't quite ready to apply that yet.
