Finding the Constants in a Motion Equation
  • Thread starter fghtffyrdmns
    Constants
29 replies · 4K views · last reply
fghtffyrdmns
If s(0) = 0, v(1) = 24 and a(t) = 24t+6 find s(t)
I know a(t) is s''(t) and v(t) is s'(t). however, How can I find s(t)?
Integrate a(t) twice. You get two undetermined constants. Find them by using the s(0) and v(1) conditions.
We have not learned integration yet :(. Infact, we have not even done anything from finding a function from it's derivatives.
Is there any other way to do it?
Have you been given any equation relating s,v, and a?
Nothing at all.
Find the anti-derivative of a(t), which is v(t).
Plug in t=1 for v(t) to get the constant.
The find the anti-derivative of v(t), which is s(t).
Plug in t=0 for s(t) to get the constant, and now you have your answer.
What is this anti-derivative? What's integration? :/
Well either you haven't been paying attention in class or there is something seriously wrong with how they are teaching you.
Since you haven't learned integration, the only possible way I can see you finding s(t) by derivatives only is knowing that since a(t) = 24t + 6, all of the integrals of a(t) must obey the power rule. Knowing this you know that
v(t) = f(t^2) and s = g(t^3)
So g(t^3) is a cubic. and can be written in the form:
q*t^3 + b*t^2 + c*t + d
can you solve from there?
Could you not do the inverse of the power rule?
The inverse of the power rule is integration. Since you know that
s = q*t^3 + b*t^2 + c*t + d
all you need to do is solve for q, b,c and d using derivatives.
I'm so lost right now.
My teacher shall get angry letters >:[
Recap: You know that s(t) is a cubic because when you take two derivatives of a cubic you get At + B which is the same form as a(t) = 24t + 6.
So using the initial conditions eg. s(0) = 0, the a(t) formula, s(t) = q*t^3 + b*t^2 + c*t + d, and knowing that s' = v and s'' = a, solve for q,b,c, and d.
Someone's been skipping class. Anti-derivative is basically doing the reverse of a derivative.
For example the derivative of 3x^2 + 5x + 4
= 6x + 5
The anti-derivative of 6x + 5
= 6x^2 * (1/2) + 5x * (1/1) + C
= 3x^2 + 5x + C
If the f(x) = 3x^2 + 5x + C
and we're given f(0)=4
then we can figure out the constant C
and we get f(x) = 3x^2 + 5x + 4
Hey guys, what's math? :p
I think I got it! My book doesn't even have this stuff in it. No, I was not skipping class. This teacher just gives us questions we've not even seen before. He does it all the time.
v(t) = 12t^2+6t
s(t) = 4t^3+3t^2 + t?
no?
not even close?
almost, v(t) is incorrect, redo the derivative of s(t) to find the correct v(t)
am i missing the constant in the v(t)? a K right?
Your s(t) is correct, now take its derivative to find v(t).
yes, you are missing a constant in v(t)
EDIT: Sorry I said that your s(t) is correct, sorry it isn't, the "t" term is wrong, you need a constant coefficient, so you need a Kt not a t. But using the initial conditions given to you, you can find what K is.
fghtffyrdmns said:
v(t) = 12t^2+6t
You need the constant, so it's
v(t) = 12t^2+6t+C
to find C, you plug in the fact that you know v(1)=24
After you find C, then you repeat the process to find s(t)
See, this is what I don't understand.
would I just write 24 = 12t^2+6t +c?
the solve for c? where does the K come from?
v(t) = 12t^2+6t + C
s(t) = 4t^3+3t^2 + Kt +C
If I'm understanding your use of variables correctly, K is C.
K is one of the coefficients in s(t), which is known by figuring out C in v(t).
v(t) = ... + C
s(t) = ... + Kt + ...
You wrote v(t) correctly, now just plug in t=1, and you'll get C.
fghtffyrdmns said:
v(t) = 12t^2+6t + C
yes, but C is not the same value or variable in both of those equations. C is just commonly used to represent an unknown constant.
The C in your first equation will be the K in your 2nd equation.
You don't. You just reused the same variable.
I rewrote it:
v(t) = 12t^2+6t + C
s(t) = 4t^3+3t^2 + Ct + D
v(1)=24
s(0)=0
Wait, I think I solved for C improperly. 24 = 12t^2 +6t + C
C = -12t^2-6t+24
t= 3/2 and -2
v(1)=24, which means t = 1. Plug in 1 wherever you have a t.
ahhh yes. I was thinking of something else sorry.
I got c at 6. which makes sense since d should be zero as s(0) = 0.
v(t) = 12t^2+6t
no?
not even close?
Close. The 't' is s(t) would give you a '1' in v(t). I don't see any. How about replacing it with a constant 'C'?
