Finding the equation of a parabola with only 2 x-intercepts and the vertex
  • Thread starter Thread starter ashers
    Parabola Vertex
The discussion focuses on deriving the equation of a quadratic function with x-intercepts at 3 and 7, and a point (5,8) that the function must pass through. Participants clarify that the quadratic can be expressed in the form f(x) = K(x - 3)(x - 7), where K is a constant that adjusts the function to meet the condition f(5) = 8. The correct approach involves substituting x = 5 into the equation to solve for K, ultimately leading to the solution f(x) = -2(x^2 - 10x + 21) to ensure the function passes through the specified point.
  • Understanding of quadratic functions and their properties
  • Knowledge of factoring polynomials
  • Ability to solve for constants in equations
  • Familiarity with the vertex form of a quadratic equation
  • Learn how to derive the vertex form of a quadratic equation
  • Study the properties of parabolas and their transformations
  • Practice solving for constants in polynomial equations
  • Explore the application of the quadratic formula in finding roots
High school students studying pre-calculus, educators teaching quadratic functions, and anyone looking to strengthen their understanding of polynomial equations and their applications.
ashers
1. Write an equation of the quadratic function f whose graph has x-intercepts 3 and 7 and f(5) = 8.
2. I really don't know where to go from here :frown:
3. obviously, is the x-int. are 3 and 7 that means they are points (3,0) and (7,0). Also, f(5) = 8 becomes the point (5,8) which i have found to be the vertex. But, at this point, I don't know how to form a parabolic equation around those three points. Please help me! :confused:
What do you know about the roots of a quadratic? You're really almost there. x=5 and x=7 are roots of f(x) and you need f(5)=8.Hint:
Think of:
<br /> (x-a)(x-b)\cdot K =f(x)<br /> <br />
Can you take it from here?
i actually have no idea how to move on from there because we haven't learned that formula. I am in CP Pre-calc in high school and the simplest solution would be great. I am not very good at math and this is a review of stuff we learned from september :/
Well if a polynomial f(x) has zeros (let's say 2 in this case, it's a quadratic), then f(x), when factored, could look like: (x-a)(x-b)*K=f(x). We say that a and b are roots of f(x) because they are zeros of the polynomial.
So you had said that (3,0) and (7,0) were solutions to f(x). Do you now see what to do?
Edit: Use the two "x-values" you have as the roots of your quadratic, and then you'll need that f(5)=8...So you will need to modify your polynomial to make it work, in other words you will need to multiply it by a factor K.
Does this help at all?
well i tried multiplying x-3 and x-7 to get the equation and i got x^2 - 10x + 21. but, if you plug in 5 as x it does't equal 8. and also if point (5,8) is the vertex that means the parabola would open downwards, which makes the equation negative. I'm still really confused though :/
You're almost there. Just find a constant to multiply f(x)=x^2 - 10x + 21 so that f(5)=8.
thanks!
so wait now all i have to do is multiply the entire formula by one constant until f(5)=8?
Well whatever polynomial f(x) has f(5)=8 must pass through (5,8).
but i still can't seem to figure out how to make X^2 - 10x + 21 pass through (5,8)
With f(x)=x^2 - 10x + 21, what is f(5)?
the answer becomes -4
so should i multiply it out by -2 so that the answer becomes 8?
Just plug in 5 into
f(x) = k(x2 - 10x + 21):
8 = k(5^2 - 10(5) + 21)
... and solve for k.
EDIT: Oops, a little too late. ;)
You got it!
THANK YOU SO MUCH! I realized i was making a multiplication error early on in the problem and this is why i could not solve it correctly. You're explanation helped so much! thanks again!
  • · Replies 26 ·
