Finding the force during impact
  • Thread starter Thread starter koii123
    Force Impact
7 replies · 5K views · last reply
koii123
An inspector performed a drop test:
He released a plastic electronic product (2kg) at the height 1.3m from the ground. The plastic product than hit the ground, and bounced 0.1m after impact. Time of contact =0.1s
Find the maximum force acting on the object during impact. Assume the ground is perfectly elastic.
Potential energy = mgh
Work done = Fd
Then, Force acting on the object = F = mgh/d
F=2(9.8)1.3/0.1
Answer is 254.8N
Is this correct?? :confused:
Please help! :frown:
It doesn't seem like there's nearly enough information given to calculate the maximum contact force during impact. In fact, even if you wanted to determine the average force during impact, you would still need to know the contact time.
Chet
Chet
actually, suppose there is enough information, how to calculate?
and how to use the contact time?
can you please teach me?
we can't assume the time of contact to be something. It should be noted in the problem.
i have updated the time of contact: 0.1s,
so how to calculate it?
wait if you want the impulse then you can just find the change in momentum without the need of the time period.
remember that it is said that ground is perfectly elastic but not the plastic box.
Using work energy theorem you can find the velocities before and after collision.
koii123... First calculate the velocity of the object just before it touches the ground ? You can use either energy conservation or kinematics equation .
