What is the Correct Formula of the Metal?
  • Context: Chemistry
  • Thread starter Thread starter lioric
    Formula Metal
The discussion centers on determining the correct formula of a metal oxide based on the provided data: "0.1 mol of metal X (Ar = 27) was burned in oxygen to give an oxide with mass of 5.1g." The calculations reveal that the mass of metal X is 2.7g, leading to 2.4g of oxygen, which converts to 0.15 moles. This results in a metal to oxygen ratio of 2:3, indicating the formula X2O3, which corresponds to Aluminium Oxide (Al2O3). The conversation highlights the confusion stemming from the question's wording and the significance of the atomic mass provided.
  • Understanding of stoichiometry and mole calculations
  • Familiarity with atomic mass and molar mass concepts
  • Knowledge of chemical formulas and balancing equations
  • Basic principles of combustion reactions
  • Study stoichiometric calculations in chemical reactions
  • Learn about the properties and applications of Aluminium Oxide (Al2O3)
  • Explore the concept of atomic mass and its implications in chemical formulas
  • Review balancing chemical equations and their significance in reaction stoichiometry
Chemistry students, educators, and professionals involved in chemical analysis, particularly those focusing on stoichiometry and metal oxide formulations.
lioric
0.1 mol of metal X (Ar = 27) was burned in oxygen to give an oxide with mass of 5.1g. What is the formula of the metal oxide if it has a relative molecular mass of 30?
The choices are
XO
X2O3
XO2
X2O
The answer says X2O
But if I add up X2O the RMM is 70 not 30
This question is confusing
I don't understand how the RMM could be 30
I haven't gone into a solution cause I found this question confusing
Something is definitely wrong with the question and the answer given.
My bet is it should read: "0.1 mol of metal X (Ar = 27) was burned in oxygen to give an oxide with mass of 5.1g. What is the formula of the metal oxide?"
I found the mass of the X by 27x0.1=2.7g
I subtracted 5.1g-2.7g=2.4g of oxygen
So changed the mass of oxygen to moles which = 0.15
Ratio it with 0.1 mol of X and I get 1:1.5
So X:O is 2:3 ratio
There for X2O3
Which makes sense cause At=27 is Aluminium
And Aluminium Oxide is Al2O3
Your logic is good but it doesn’t apply to what is asked. The truly confusing part is the “(Ar=27)” and the 5.1 g. :)
If we ignore that part, the rest of the question tracks normally.
If RMM=30:
XO case: atomic mass X = 14 (N, nonmetal)
X2O3 case: atomic mass X= -9 (not real)
XO2 case: atomic mass X=-2 (not real)
X20 case: atomic mass X=7 (Li)
This should be the end of the problem.
balanced equation
2Li (.1 mol) + 1/2O2 ——-> Li2O (.05 mol)
It does make 1.5 g of product. A dyslexic 5.1 g?
Let's not confuse the OP further. Question asks what is the formula and that's exactly what OP calculated, so their logic applies. Answer depends on which parts of the contradicting information given in the question one considers erroneous and decides to ignore.
  • · Replies 25 ·
