Finding the gravitational force
To find the gravitational force on mass 1, which is 2 kg, the user needs to apply the formula F=F12+F13, considering the forces from the other masses. The configuration resembles a triangle, and the net force can be calculated using the principle of superposition. It's important to analyze the angles and components of the forces, as some may cancel out if the triangle is equilateral. The user is preparing for a physics test and seeks clarity on these calculations. Understanding the geometry and applying the correct formulas will help solve the problem effectively.
nissanfreak
This is the last question I have on my study guide that I can't solve. My physics test is tomorrow and I just want to be ready for it. Please help me figure this one out!
What is the gravitation force on mass 1 if each mass is 2 kg?
O<---(5m)---->O mass3
I -
I -
(2m) -
I -
O - < mass1
Well I hope you can understand that.
I know that the hypotonuse is the square root of 29 so I am guessing I need to use the formula F=F12+F13 to get the answer right or wrong?
well my crude attempt at a diagram didnt come out so good lol. But its supposed to look like a triangle.
If you're trying to use the net force, then you will want to use superposition, which is basically what you are implementing. If its an equilateral triangle then some components will cancel, depending on how the triangle is configured.
