Finding the kernel and range of a tranformation
  • Thread starter Thread starter Noone1982
    Kernel Range
11 replies · 12K views · last reply
Noone1982
If L(x) = (x1, x2, 0)^t and L(x) = (x1, x1, x1)^t
What is the kernel and range?
You have defined two different functions. Which one are you referring to?
Do you know the DEFINITION of "kernel"
I need to do both. I know the kernel is basically setting to zero, but my book is awful on explaining stuff. I also know the range is basically solving for y and row reducing, but I am foggy on the presentation.
I'll explain it to you, and I want to see you attempt to answer it.
The range is simple. It's just like Calculus, sort of.
For example, the function f(x)=x^2 has a domain of R(-infinite,infinite), and range (0,infinite).
The range is simply all the possible vectors you can obtain from the transformation. If T(x) = (0,0), then all the possible vectors that come "out" of the transformation are in the set {(0,0)}, which is the range.
What's the range of T(x)=(x,y)?
The answer is R^2, which is any vector in the Cartesian Plane.
The kernel of a transformation is the set of vectors that transform into the zero vector. So, for the first one T(x)=(0,0) is all the vectors, since all the them become a zero vector, so the answer is R^2.
What's the kernel of T(x)=(x,y)?
Well, the only possible vector that can transform into a zero vector is the zero vector itself.
Note: I have no idea what you mean by exponent t. Maybe that signifies that it is a transformation... I have no idea.
Your book is awful on explaining "setting to zero"?? Not a whole lot to explain is there?
For your first function L(x1,x2,x3))= (x1, x2,0).
Set that equal to 0: (x1, x2,0)= (0, 0, 0).
What does that tell you about x1 and x2? What does it tell you about x3?
Now the range: what do all possible values of L, that is all vectors of the form (x1, x2,0), have in common?
It means transpose. For example (5,2,3) is a row matrix (i.e., a 1x3 matrix) and (5,2,3)^t is a column matrix (i.e., a 3x1 matrix).
Regards,
George
Regards,
George
I know what transpose means. :-p
Then I'm surprised that you don't know that AT is a standard notation for transpose.
Exactly... capital T. :-p
You can't guess that lower and upper case t in an expression x^t or x^T where x is a vector don't both obviously mean transpose?
I didn't think the transpose was necessary.
Anyways, the question isn't about transposes.
It's about vectors, and linear maps. What on Earth was it going to be except transpose?
