Finding the Length of a Small Square
8 replies · 3K views · last reply
dirk_mec1
Geometry diagram: a square inscribed in a circle, with a smaller square drawn below sharing its bottom side, its two lower corners touching the circle. Text beside it asks for the ratio of the large square's area to the small square's area.
a>
2. Homework Equations [/B]
I can find the length of the large square.
The small square is where the trouble starts.
If I look at the part of the circle where the small square is and put a center of a coordinate system at the bottom part of the circle I can setup an equation for the arc from the lowest point on the circle to the lower right corner of the large square.
[tex]f(x) = R-\sqrt{R^2-x^2}[/tex]
I know that there is some x at which the height up until the large square is twice the x-value:
2x = H - f(x)
with H the length of the lowest point of the circle up until the large square.
[tex]H = R-Rcos(45)[/tex]
Now if I solve 2x = H - f(x) I get:
[tex]5x^2 + 2\sqrt{2} Rx + 0.5R^2 = 0[/tex]
Which does not lead to the correct answer. The answer of the length of the small square is
[tex]\frac{R \sqrt{2}}{5}[/tex]
What am I doing wrong?
dirk_mec1 said:
a>
2x = H - f(x)
I don't have time to check your work at the moment. What I would do is use some basic right triangle trig to get the dimensions of the two squares. For simplicity, I would assume that the radius of the circle is 1. Then find the length of a side of the large square. If you know the dimensions of the large square, the length of a side of the small square is 1 - (1/2)(length of a side of the large square). Knowing the length of a side of each square, you can get the ratio of the areas of the two squares.
Mmm. Can't really agree. It's actually a bit less that that.
I know that there are other methods. I want to know where MY method is going wrong.
Your quadratic equation ought to read 5x2 + 2√2Rx - 0.5R2 = 0
Yes, you are right -- my mistake. I wasn't taking into account that the distance from the lower edge of the large square to the circle isn't equal to the length of a side of the smaller square.
True this was a typo but I still do not get the right answer.
When I solve the corrected quadratic equation:
## 5x^2 + 2\sqrt{2} Rx - 0.5R^2 = 0 ##​
I get the correct result.
Yes I figured it out. When I solve it I need to multiply with 2 to get the length!
