Finding the locus, seriously quick
  • Thread starter Thread starter help4drdu
5 replies · 4K views
help4drdu
1. Given the points A(1,4) and B(-3,2), find the equation of each locus of the pont P(x,y), a) angle APB is a right angle
b) P is equidistant from A and the x-axu
ok for:
a) The key point is that it's a right angle, so simply use [tex]M_{PA}M_{PB}=-1[/tex] where M is the gradient of each line. You will end up with an equation in x and y, which is your locus.
b) Since P is equidistant from the x-axis (y=0) and A(1,4) use the distance formula.
thanks for your quick response, but could you please explain a) i seem to be having trouble i understanding the equation you have written.
Sure, no problem.
Are you familiar with the fact that if two lines are perpendicular to each other, their gradients multiply to give -1?
Such as y=x and y=-x, their gradients multiplied together give: (1)(-1)=-1 and thus these lines are perpendicular (right angles) to each other.
So [tex]M_{PA}[/tex] is the gradient of the line PA, which is found by using the gradient formula,
[tex]\frac{y_2-y_1}{x_2-x_1}[/tex]
If you're still unsure, just ask :smile:
Thanks! That makes it a lot more clearer now. Also thanks for your fast responses. =] Hope you have a great day =]
