Finding the maximum value given an interval
The problem involves finding the maximum value of the function f(x) = x^a(1 - x)^b on the interval 0 ≤ x ≤ 1, where a and b are positive numbers. Participants are discussing the derivative of the function and its implications for determining critical points.
  • Participants discuss setting the derivative f'(x) to zero and explore potential solutions, including factoring and identifying critical points. There is uncertainty about how to simplify the derivative and whether certain values of x are valid solutions.
The discussion is ongoing, with participants providing insights and corrections regarding the derivative and the nature of the solutions. Some participants have suggested that the maximum value may depend on the parameters a and b, while others are clarifying the distinction between finding the x-coordinate of the maximum and the maximum value itself.
There is mention of a hint provided in the problem regarding the dependence of the maximum value on the parameters a and b. Participants are also addressing potential typos in their calculations that may affect their results.
PandaherO
If a and b are positive numbers, find the maximum value of f(x) = x^a(1 - x)^b on the interval 0 ≤ x ≤ 1.?
f'(x) = x^a . -b(1-x)^(b-1) + (1-x)^b . ax^(a-1)
I know to set f'(x) = 0 but I'm not sure how I'm supposed to tidy up the f'(x) above..
Either x or (1-x) are solutions, or otherwise you can divide away x^a and (1-x)^b.
Set f '(x) equal to zero.
xa b(1-x)(b-1) + (1-x)b ax(a-1) = 0
Now factor out (x(a-1) (1-x)(b-1)).
There is one solution in addition to the two mentioned by I like Serena.
the question also gave a hint that my maximum value may depend on a and b
so (x^(a-1) (1-x)^(b-1)) (a(1-x)+bx) =0
then do I set (a(1-x)+bx)=0?
and solve for x?
i got x=a/(a-b) and it isn't the correct answer...
You made a typo with a minus sign, giving you the wrong result.
Furthermore, if I read your problem correctly, it asks for the maximum value, not the x-coordinate of the maximum value.
You have 3 solutions: x=0, x=1, and this one.
You should substitute those and pick the greatest for the maximum value.
OHH no wonder...*facepalms myself* the minus sign... and yea, the problem wanted the x and y coordinate)
Thank you so much owo
  • · Replies 26 ·
