Finding the minimum distance between two cars
13 replies · 4K views
titansarus
We have two cars moving like the picture. we want to find their minimum distance using relative motion.
I) Consider a coordinate system on M, which has two axis. one axis is in direction of MP and the other is perpendicular to that (Something like r_hat and θ_hat). Find the velocity of p in the new coordinate system.
II) Describe the movement of P from M viewpoint (I think it means find the equation of motion)
III) Using II, find minimum distance between the two cars?
IV) Prove that the minimum distance is zero if and only if dp/vp = dm/vm.
The picture is from Fundamentals of Physics/Resnick,Walker,Holiday but the question is different from the question of the book.
Don't Know.
I can completely solve this without the new coordinate system and using only i and j. But I have problems with this new coordinate system. I can also find something like vp→ = -vp sin θ r_hat + (-vp) cos θ θ_hat. θ is the angle between MP and Y axis. But I don't know how to find the equation of motion and solve the other parts. using the method in the question.
This is a relative velocity problem. Start with question (I). Assume that you are the driver of car M. What is the velocity of car P relative to you? Use ##\hat i## and ##\hat j## for your description.
As I said in the the attempt at the solution part, I can solve this with i and j. But it seems the question wants it to be solved with ##\hat r## and ##\hat θ##.
Please post the statement of the problem exactly as was given to you. You mention "something like r_hat and θ_hat", but I doubt that's how it was given to you. Is there a different diagram that shows angle ##\theta##? Also, for (II) the question does not say to use ##r## and ##\theta##, so it seems you can use the Cartesian axes to answer it.
Is is because the University teacher, showed this picture in holiday physics and then asked the question orally and said use something like r_hat and θ_hat (as a hint). So it is unknown to me that where he get the question and what is the exact statement. Usually, Books don't force anyone to use just one approach to solve a question but in this case, the question giver wants it to be solved only with ##r## and ##\theta##.
I think this picture, describe the question coordinates better: (theta hat and r hat are perpendicular)
That's good.
1. Express ##\vec v_{rel}## in terms of ##\hat i## and ##\hat j##.
2. Draw a new drawing, based on the one above, showing the four unit vectors ##\hat i##, ##\hat j##, ##\hat r## and ##\hat \theta##.
3. Find the coefficients ##a_{kl}## such that ##\hat i=a_{11}~\hat r+a_{12}~\hat\theta## and ##\hat j=a_{21}~\hat r+a_{22}~\hat\theta##. They should be sines and cosines involving ##\theta.##
4. Substitute in 1.
kuruman said:
That's good.
4. Substitute in 1.
I think ##\vec v_{rel}## = -vp ##\hat i## + vm ##\hat j##. Also ##\hat i = - cos \theta \hat r + sin \theta \hat \theta## and ##\hat j = sin \theta \hat r + cos \theta \hat \theta##
and after substitution we get an equation for ##\vec v_{rel}## in term of ##\hat r , \hat \theta ,sin ,cos## of## \theta ,vm,vp ##. Now, How should I write equation of motion? because the theta itself is not constant and change with time (as the get closer).
Please show your drawing of the four unit vectors. I am not sure your answers have the correct signs. Also, remember that ##\vec v_{rel} ## is the velocity of P relative to M. If P were not moving (## v_P = 0##), driver M should see P moving in the ##\hat j## direction. Your expression does not predict that.
Yes. The ##v_{rel}## part was a typo. But in the i and j part, I think I used j instead of i. so they are actually ##\hat j = - cos \theta \hat r + sin \theta \hat \theta## and ##\hat i = sin \theta \hat r + cos \theta \hat \theta## and ##\vec v_{rel}## = -vp ##\hat i## + vm ##\hat j##
So ##\vec v_{rel} = -(v_p sin \theta +v_m cos \theta) \hat r + (-v_p cos\theta + v_m sin\theta)\hat \theta##. I don't know what to do with this to write equation of motion. Because ##\hat r , \hat \theta## are not constant and they also change with ##\theta##.
Right, but you can always write the position of P relative to M in Cartesian coordinates (##\vec r = \vec r_0 +\vec v_{rel}~t,## then just rewrite the Cartesian unit vectors in terms of the polar unit vectors.
Yes I can rewrite every cartesian coordinates in terms of polar coordinates. But how I must differentiate the ##\vec r## in polar coordinates to find the minimum distance? I know the principle of differentiation of polar vectors like ##\dot \theta \ddot \theta## and others but the problem is that in this case, ##\theta## will be a ##arctan## function in terms of ##t## and differentiating the whole equation will result a very big equation (I think), and then solving the ##\dot r=0## will be more difficult. I want to know is there any technique to not calculate the very big derivative?
You can avoid a lot of messy calculations if you realize that the distance between the two cars is a scalar quantity and is therefore independent of your choice of coordinate system. Write an expression for the distance and minimize that. Better yet, the square of the distance is a minimum at the same time as the distance is at a minimum so minimize the square instead. The position of P relative to M is ##\vec r = \vec r_0 +\vec v_{rel}~t##. What is the distance squared between M and P? If you follow this route, the answer drops out relatively quickly. The answer drops out extremely quickly if you observe that a certain quantity (which one?) is conserved.
This problem is simple because the object has zero acceleration and moves in a straight line. In general, the condition for closest approach is that the radial component of the velocity vector be equal to zero. I think that's what your instructor wanted you to realize.
