Finding the net force from two forces without mass
16 replies · 3K views · last reply
rculley1970
I have a frictionless force problem. A car is traveling north and there is a Y intersection. 480N to the left at 11 degrees, 400N to the right at 26 degrees. Can I find the magnitude and direction of these 2 forces without the mass of the car?
I am coming up with 155.6N but am still working on the direction.
We can't tell whether the 11 degrees is measured clockwise from the left direction, (ie, 11 degrees toward negative y from the negative-x axis?)
or whether it is 11 degrees clockwise from the left (11 deg toward +y from-x)
Find each component first, of each Force. Then add each component separately.
Finally use Pythagoras to get the magnitude of the total Force, if needed.
use the inverse tan(Fy/Fx) to get the angle.
Sorry, I meant it going north as in the y direction. 11 degress going negative from the y-axis and 26 degress going positive from the y-axis. I forgot about the inverse tangent function to find the angle. thank you for that. This is what I have:
F(x)=-480(cos11) + 400(cos26)
F(y)=400(sin26) + 480(sin11)
F(x) = -111
F(y) = 267
a = .099 m/s^2
Just let me know if this is wrong. I will rerun the numbers again to verify.
From your description, I expect each Force to be mostly in the y-direction.
But using -480N cos(11) makes almost all the Force in the (-) x-direction ...
Should you switch the sines with the cosines?
(yes, if the 11 degree angle is measured from the y-axis)
You can't predict an acceleration without knowing the mass, though.
Not sure if i can put a graphic on here but:
480N \11 deg |26 deg / 400N
figured out the magnitude. 914.8. but still working on the angle.
That's what I thought - these small angles are being measured from the y-axis.
So the small components are the x-components, with large y-components.
Verify by adding the component VECTORS (tail-to-tip) to get the diagonal.
sin(11) = - F1x / F1 ... sin(26) = + F2x / F2y
thank you for the help, lightgrav. I did mix up the cos and sin. had them backwards. I am using the ThompsonNOW website where the teacher posts the homework. The mag is 914.8 and the a=.288m/s^2. Just trying to figure out the angle though. Give me a few minutes on this one.
Sorry, mass was given in part (b) of question: 2900Kg. Part (a) just asked for mag and dir. (b) asks for acceleration
Even if the Forces were perfecly aligned, they would only add up to 880N !
The result of a vector addition is never greater than that ... NOT 914.8 N
(I got 834N).
Odd, I can input the answers and it tells me if they are correct or incorrect. On the mag and acceleration, i got 914.8 and .288 respectively. It gave me credit for both of them. I keep getting the angle wrong though. will keep working on it.
F(x)=-480(sin11) + 400(sin26) = 83.8
F(y)=480(cos11) + 400(cos26) = 831
a(x)=(83.8)/(2900) = .029
a(y)=(831)/(2900) = .287
a = .288
I keep coming up with 84.2 degrees but the website keeps telling me it's incorrect.
The magnitude of the Force vector is obtained by Pythagoras, not straight addition.
If their angles are measured from +y-axis, yours probably should be, too.
Crashing out for the night. Working on it tomorrow along with some friction problems. (ughhh) Too many equations. Mostly memorization of equations and when to use them from what I can tell. Will look into the current problem tomorrow. Thank you for your help.
