Finding the Nth Term in a Series with Different Factors
StatusX
Homework Helper
I'm trying to get an expression for the nth term in this series:
c_1 = 1
c_n = \sum_{k=1}^{n-1} \frac{c_n}{(n-k)!}
For example:
c_2 = 1/1! = 1
c_3 = 1/2! +1/1! = 3/2
c_4 = 1/3! + 1/2! + 3/(2\cdot 1!) = 13/6
etc.
Since the factor in front of each term is different in each series, you can't express c_n just in terms of c_{n-1}. I have no idea how to start.
First, that is supposed to be ck inside the sum. It's too late to edit it.
Is no one replying because this is too hard or too easy? If it helps, this was found when I was trying to derive a formula for
\sum_{n=1}^{\infty} \frac{1}{n^{2k}}
I know this involves the Bernoulli numbers, so maybe they are involved in the series from my first post.
I was using Fourier series to find an explicit formula. Namely, I started with a sawtooth wave with Fourier coefficients proportional to 1/n. Then I normalized it so the integral over one period was one, which meant that:
\sum_{n=1}^{\infty} |c_n|^2 = 1
From which I got the first sum (k=1). Then I integrated to get a series with 1/n2,l fixed the constant so there were only sinusoidal terms in the Fourier series, and renormalized. I correctly got the formula for k = 1, 2, and 3. Then trying to find the general form, which is made complicated by the integrating constants that depend on the constants from previous iterations, I ran into a series very similar to the one from the first post. I was just curious if there is a closed form for that expression, or if you have to resort to more complicated methods.
Maybe this will help, although I don't surely know cause I haven't tried it yet, but I recall a method I used to solve a similar problem once.
Set:
f(x) := c_1 + c_2x + c_3x^2 + c_4x^3 + c_5x^4 + ...
where c_k are the co-efficients you originally defined.
Then expand the inverse of f(x) as a power series, call this new power series g(x), say. I'm assuming the co-efficients of g(x) might be easier to recognise. If you have maple or mathematica this can be easily done.
Then the c_n co-efficients of f(x) can be calculated by knowing the n'th derivitive of 1/g(x) , evaluated at the point zero.
If you can calculate it, I'd be interested to know what the power series of g(x) is.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
