Finding the particular/complementary solution from a laplace transform
To determine the complementary and particular solutions from a Laplace transform, one cannot strictly define them based solely on their behavior as time approaches infinity. The distinction between these solutions is inherently flexible and can vary based on how the overall solution is expressed. For instance, constants in the solution can be adjusted, leading to different interpretations of what constitutes the complementary and particular components. Ultimately, the classification of parts of the solution is a matter of choice rather than a fixed rule. Understanding this flexibility is crucial for accurately interpreting solutions in the context of differential equations.
eggshell
Say you find the laplace transform V(s) and want to switch it back to the time domain, once you've done this, how do you determine which parts of the total solution correspond to the complementary solution and particular solution respectively? Do you just find which parts approach zero as time increases to infinity, and label that as the complementary, or is there more to it than that?
Strictly speaking, you can't. If, for example, y(x)= Cf(x)+ Dg(x)+ h(x) is a solution to the differential equation, where C and D are undetermined constants, so that Cf(x)+ Dg(x) is the "complimentary solution" and h(x) is the "particular solution, we could just as easily write y(x)= (C- 1)f(x)+ (D- 2)g(x)+ (f(x)+ 2g(x)+ h(x)) so that (C- 1)f(x)+ (D- 2)g(x) is the "complimentary solution" and f(x)+ 2g(x)+ h(x) is the "particular solution". In other words, what part of a solution is "complimentary" and which is "particular" is purely a matter of choice.
  • · Replies 52 ·
