Finding the position x(t) with constantly changing acceleration
To find the position x(t) of an object with changing acceleration defined as sin(2t), the process involves integrating the acceleration to determine the velocity function v(t). The initial velocity is given as -1/2 at time t=0, which helps establish the constant C in the velocity equation. By substituting t=0 into the derived velocity equation, the correct value for C can be determined, ensuring the initial conditions are met. After obtaining v(t), the next step is to integrate this function to find the position x(t). This method provides a systematic approach to solving for position with varying acceleration.
alpha01
Im trying to find the position of an object x at time t. There is pretty straight forward formulas to use to find x(t), however acceleration must be fixed... but in this question acceleration is changing at sin2t.
I have been going through period by period working out the new position at x(t-1).. until i finally get to the time i want.
surely there is an easier way to work out the position at time t when acceleration is constantly changing?
There is indeed a far more straightforward method to determine x(t), simply consider the definition for acceleration.
a = x^{\prime\prime}\left(t\right) = \sin\left(2t\right)
thanks, i can see how that is true. However i can't put it all together.
The object is moving at v = -1/2 at time 0, from a starting point of 5 on a grid.. how can i find out where the object is 5 seconds later?
Is it the integral of the integral of acceleration (sin2t) where t = 5?
alpha01 said:
Is it the integral of the integral of acceleration (sin2t)?
No, try taking it one step at a time. First determine v(t)
v\left(t\right) = x^\prime\left(t\right) = \int \sin\left(2t\right) dt
(-1/2)cos(2t)
alpha01 said:
(-1/2)cos(2t)
Good, but aren't you forgetting something?
woops...
(-1/2)cos(2t) + C
alpha01 said:
woops...
(-1/2)cos(2t) + C
Better. So what can you say about this constant C?
C = acceleration at t?
No. We have found an equation for the velocity at time t,
v\left(t\right) = C - \frac{1}{2}\cos\left(2t\right)
Let me rephrase my question: what do the initial conditions tell you about the value of C?
i think that C is the initial velocity of -1/2?
Close, but not quite. Try substituting t=0 into the equation for v(t) above.
ok, so using C = -1/2 we get v(0) = -1, and using C = 1/2 we get v(0) = 0
neither of which gets our true initial velocity of -1/2... the only way i found to get the correct initial velocity at t(0) is using C = 0.
when t = 0 you get
v\left(0 \right) + \frac{1}{2}= C
You need to look at your question to find out what the value of the velocity is at t = 0
Once you get that, you'll find a number for C and the velocity is known as a function of time.
Then, you can do the entire same thing :
integrate the formula you found for v(t) to get to x(t)
marlon
  • · Replies 24 ·
