Finding the reaction force on a 5m mass
7 replies · 3K views · last reply
bomberkid
. question is as attached. answer is 2f/5..how do u get this?
F=ma
F= (5m)a
a= F/(5m)
gotten a=F/5m , but why the answer is 2f/5?
  • Diagram of two blocks on a frictionless horizontal surface: a force F pushes a large block labelled 3M, which touches a smaller block labelled 2M. Below are answer choices A to D: 3F/2, 2F/3, 3F/5, 2F/5.
What force is necessary to produce your calculated acceleration in the second block?
No... you calculated the specific ##a##, now put that back into ##F=ma## along with the second block's mass
Unfortunately the confusion between the abstract "F" and the specific "F" in this problem is perhaps making understanding a little harder than it should be.
bomberkid said:
I see. Why not use the mass 3m?
Either will do provided you bring all relevant forces acting on the mass into the equation.
but if i were to use f=3m, and a is F/5m, i wouldn't get 2f/5 as the answer
You get the right answer if you bring in all forces acting on the mass and do the algebra correctly. Please post your working.
