Finding the residue of a pole of order 2 (complex analysis)
The discussion revolves around finding the residue of a function with a pole of order 2, specifically f(z) = z / (z^2 + 2aiz - 1)^2. The singularities are identified at points A and B, but the initial attempt to compute the residue using the standard limit method fails. The correct approach involves differentiating a modified function, leading to the expression -(z+B)/(z-B)^3, and evaluating it at z=A. Ultimately, the correct residue is obtained by substituting the values of A and B into this derived expression. The participant resolves the issue independently, indicating a successful understanding of the problem.
mxmt
The problem
Find Res(f,z1)
With: f(z)=\frac{z}{(z^2+2aiz-1)^2}
The attempt at a solution
The singularities are at A=i(-a+\sqrt{a^2-1}) and at B=i(-a-\sqrt{a^2-1})
With the normal equation (take limit z->A of \frac{d}{dz}((z-A)^2 f(z)) for finding the residue of a pole of order 2, my attempt fails.
I know the way the correct answer is constructed, but I do not understand it.
The solution is namely: take \frac{d}{dz} of \frac{z}{(z-B)^2}
This is: \frac{-(z+B)}{(z-B)^3}
Then plug in z=A, which gives: \frac{-(A+B)}{(A-B)^3}
Now plugging in the values of A and B give the correct answer.
Any help is appreciated.
Never mind, I figured it out.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
