Finding the Solution: Solving for x in a Polarization of Light Equation
  • Thread starter Thread starter johnsobertstamos
    Light Polarization
The discussion revolves around solving for the number of polarizers required for light to reach a specific intensity, specifically 1/9 of its original intensity, using a polarization equation. The subject area includes concepts of light polarization and mathematical reasoning related to logarithmic functions.
  • Participants discuss the setup of the equation and the interpretation of the intensity reduction. There are attempts to clarify the phrasing of the problem and the implications of the calculations involving logarithms. Some participants question the correctness of the original poster's calculations and suggest checking assumptions about the number of polarizers.
The discussion is ongoing, with participants providing guidance on checking calculations and assumptions. There is a recognition of potential errors in the original calculations, and some participants suggest alternative approaches to the problem. Multiple interpretations of the problem statement are being explored.
Participants note that the problem specifies the answer must be in integer form, and there is a discussion about the implications of the decimal part of the calculations. The original poster expresses confusion over the correctness of their answers, indicating a need for further clarification.
johnsobertstamos
A series of polarizers are each placed at a 12 ∘ interval from the previous polarizer. Unpolarized light is incident on this series of polarizers. How many polarizers does the light have to go through before it is 1/9 of its original intensity?
I = Io (cos theta)^2
Iintensity polarized = 1/2 Intensity unpolarized
I set up the equation
.5((cos 12)^2)^x = 1/9
Solving for x gets me 34.037
34 + 1 = 35
I've entered answers of both 34 and 35 and both have been marked as wrong. Does anybody know what I'm doing wrong here?
Welcome to the PF.
johnsobertstamos said:
How many polarizers does the light have to go through before it is 19 of its original intensity?
19 what of its original intensity? 19%?
Welcome to the PF.
Sorry, should be 1/9
Ah, okay thanks.
Do both of those equations apply to the first and all subsequent polarization stages?
The bottom one applies to just the first, reducing the intensity by half. The top one applies to the rest of the polarization stages.
34 + 1 = 35
I get a different value of x for the solution of that equation, where x is the number of polarizers after the first one. Could you show your work so we can check it please? Thanks. :smile:
[tex]I(x) = \frac{1}{2} [cos^2(12)]^x[/tex]
Yes, sorry, I deleted my post after I made it because I realized that you had already factored that in. Please check out the reply that I just made. Thanks.
"How many polarizers does the light have to go through before it is 1/9 of its original intensity?"
Is that the exact phrasing of the original problem statement? Perhaps it says something equivalent to "less than 1/9 of the original intensity"? In that case the ".037" in the resulting calculation might play a role... Just a thought.
That's the phrasing given in the problem. I also forgot to mention it asks for the answer in the form of an integer.
1) .5((cos 12)^2)^x = 1/9
2) ((cos 12)^2)^x = 2/9
3) x ln((cos 12)^2) = ln (2/9)
4) x = (ln (2/9)) / ln((cos 12)^2)
5) x = 34.037
Still at a complete loss for what I'm doing wrong here. My math checks out every time.
I think you should be using log(), not ln()... :smile:
It gets me the same answer of 34.037 Any differences in the equations we have set up?
I'm inputting
x = log(2/9) / log((cos 12)^2)
x = 34.037
Hmm, I found an error by a factor of 2 just now in my previous calculation, and now I get the same as you: 1+34=35. Can you check with a TA or the instructor?
Right. With 35 filters I get that the resulting intensity is still a wee bit above 1/9 the initial intensity.
Ah so maybe it's 36 then
That seems like the most likely option at this point. Can you check it?
Yep 36, thank you everybody for your help. Much appreciated!
  • · Replies 25 ·
  • · Replies 105 ·
