Finding the tangential speed Help
  • Thread starter Thread starter Ester
    Speed
The discussion centers on calculating tangential speed using the formula v = rω, where v is tangential speed, r is the radius, and ω is angular velocity. A participant initially miscalculated by doubling their time, which incorrectly affected their angular velocity. After clarifying the relationship between time, angular velocity, and tangential speed, they confirmed that their final answer of 4.65 m/s is correct given the right radius and angular velocity. The conversation emphasizes the importance of understanding the relationship between these variables in physics calculations. Accurate application of the formula leads to the correct determination of tangential speed.
Ester
Finding the tangential speed... Help
i got it, it I shouldn't have doubled my time. My answer is 4.65 m/s right?
It's easier than you think. You have the angle the ball rotated. How much time did it take? (Hint the ball is traveling with a constant horizontal speed and the distance is given. Find the travel time.) Use this to find the angular speed (\omega). Then use v = \omega r.
Yes, that is correct! The formula for tangential speed is v = rω, where v is the tangential speed, r is the radius, and ω is the angular velocity. Doubling your time would mean doubling the angular velocity, but keeping the radius the same. So if you had the correct radius and angular velocity, your answer of 4.65 m/s would be correct. Great job!
  • · Replies 20 ·
