Finding the trace of a matrix where A⁴ = 16
  • Thread starter Thread starter Tanishq Nandan
    Matrices
18 replies · 3K views
Tanishq Nandan
A.A^-1=Identity matrix
Trace of a matrix [tr(A)]is the sum of elements on it's main diagonal.
In the given equation,post-multiplying A^-1 (A inverse) on both sides gives A^4=16.
Since the array contains only one element (say x),this can only mean that x^4=16,
which means that x is either 2 or -2.So,the trace of the matrix can also correspondingly be 2 or -2
Sure enough,the answer given is 2,but how do we eliminate -2?
There's nothing in the question which says the matrix elements can't be negative.
That would mean I'm most probably missing something basic.
Help appreciated.
The problem is kind of hard to read / interpret to be honest.
Why do you think ##\mathbf A^{-1}## exists?
You're not given that matrix A is invertible, so ##A^{-1}## is not guaranteed to exist.
No, I don't think this is true. As I read the problem, A is an n x n matrix, each of whose elements is the product of two real numbers.
The problem wording seems a bit odd to me.
Sure enough,the asnwer given is 2,but how do we eliminate -2?
Help appreciated.
Yeah,valid point..guarantee for A^-1 to exist.
Yep,with n=1 to make it simple
I know..the first part went entirely above me.
I just did whatever I could from the given equation.
That too,apparently turned out to be wrong.
When you're working with matrices, it's better to work with at least 2 x 2 matrices.
You are given that ##A^5 = 16A##, which is equivalent to ##A(A^4 - 16I) = 0##. I would start be factoring the left side completely, but not assuming any particular size for the matrices.
But the question has already said that the matrix consists of a single element,a(ij)
A is a singleton matrix.I thought that's what the first part meant.
No.
The notation ##[a_{ij}]##, with ##1 \le i \le n## and ##1 \le j \le n## means that the matrix A is n X n. At least, that's the usual meaning. I don't get the connection with u and v, though.
Oo..alright
Me neither
I think what they're saying is that ##\mathbf A## is a rank one matrix in reals, i.e.
##\mathbf A = \mathbf {uv}^T##
hence
##trace\big(\mathbf A\big) = trace\big(\mathbf {uv}^T\big) = trace\big(\mathbf {v}^T\mathbf u \big)=\lambda ##
If you're not familiar with diagonalization, you can attack this just with extensive use of cyclic property of trace. However, the problem seems underspecified.
StoneTemplePython said:
I think what they're saying is that ##\mathbf A## is ...
Yes. That's how I read this problem. u and v are column vectors.
The issue is it's a terrible problem.
suppose
##\mathbf u = \mathbf 0##
Then
##\mathbf A = \mathbf {uv}^T= \mathbf{0}##
i.e. ##\mathbf A## is the zero matrix which is in fact rank zero. This allows ##\lambda = 0## as a solution. To get the 'official' solution of only ##\lambda = 2##, it needs to say that all entries in ##\mathbf u## and ##\mathbf v## are positive or some other condition that is considerably more restrictive than the original question.
I don't think I got that..
Are you familiar with the cyclic property of the trace? If not, I'd drill that as it's quite important in many different situations and can give you insights to this problem.
As is, the problem you posted with the solution of just ##\lambda =2##, is broken.
Help appreciated.
You haven't missed anything - you're right on target. :oldsmile:
With u=(1) and v=(2), we get A=(2), which satisfies all conditions, and which has trace 2.
With u=(1) and v=(-2), we get A=(-2), which also satisfies all conditions, and which has trace -2.
Just for fun, with u=(0) and v=(0), we get A=(0), which also satisfies all conditions, and which has trace 0.
In other words, with the given information we cannot tell what the trace is, and we have a counter example for the given answer.
Going a little beyond, the given equation implies that we can only have eigenvalues -2, 0, and 2 (and pairs of -2i and +2i that cancel), all with unknown multiplicities.
The trace is the sum of the eigenvalues, so I believe the only thing we can say is that the trace is an even integer.
Just checking, is there any additionally information given before the whole set of problem statements?
