Finding Time Given Number Of Trials And Precision
  • Thread starter Thread starter lalover
    Precision Time
The discussion revolves around measuring the specific activity of a radioactive source using an electronic counter and timer to determine the number of decays over a time interval. The goal is to achieve a precision of 1% in the measurement of decays, with an initial observation of 1000 decays in 5 minutes.
  • Participants explore the relationship between the number of measurements (N) and the desired precision, considering the formula 1/sqrt(N) as a basis for their calculations. Questions arise regarding the conversion of relative error to absolute error and the implications of the 1% precision requirement.
There is a productive exchange of ideas regarding the calculations needed to determine the appropriate measurement time to achieve the desired precision. Some participants express uncertainty about the definitions and conversions involved, while others clarify the relationships between relative and absolute error.
Participants are working under the constraints of achieving a specific precision level and are discussing the implications of their calculations based on the initial measurement of decays. There is acknowledgment of potential confusion regarding the definitions of error types.
lalover
We want to measure the specific activity (number of decays per second) of a radioactive source so that we can use it to calibrate the equipment of the gamma-ray experiment. We use an electronic counter and a timer to measure the number of decays in a given time interval. In round numbers we measure 1000 decays in 5 minutes of observation. For how long should we measure in order to obtain a specific activity with a precision of 1%? Explain.
I'm not sure where to begin. I thought about using the formula 1/sqrt(N), but wasn't sure if I could set that equal to the percent of precision (1%). I also hope I put this question in the right category. Thanks in advance!
You're on the right lines by using 1/sqrt(N) = error. You've just got to work out how to say '1%' in a different way.
Yeah I was thinking of using '.01' and setting it equal to 1/sqrt(N). If I did that, I got an answer of 50 minutes. Does that thinking seem reasonable? Thanks.
Well don't you have to convert the relative error by the amount measure to get absolute error? So would it be 0.01 times 1000? I'm not sure what the amount measured would be here.
Yes that's what I had in mind when I read the OP. Make [itex]\sqrt{N}/N = 0.01[/itex], which corresponds to 10000 counts or approximately 50 min.
BTW. I'm assuming that your 1/sqrt(N) comes from sqrt(N)/N, right?
Well our professor just gave us 1/sqrt(N), but I can see how it's equivalent to sqrt(N)/N. So you disagree with what davo789 said?
Sorry chaps, I've just realized that I've got myself into a terrible muddle!
sqrt(N) is the absolute error on N. So therefore, as you say, sqrt(N)/N is the relative error, and uart's answer is correct, of course! I've edited my OP just to make things clear; apologies for any confusion!
So the original answer of 50 minutes is correct? And "precision of 1%" is just another way of saying the relative error is equal to .01? Thanks again.
Yes, 50mins is correct. Yes, those two statements are equivalent. What you have found is how many measurements you need to take before you have the accuracy/error/precision of 1%.
Ok, great. Thanks a lot.
